2001 rx300 antenna
2001 rx300 antenna
my power is half extended and won't move up or down, I can still hear the motor humming when I turn the radio on and off, need help
Take it to Lexus or Toyota and drop $200, or DIY. Order a new antenna and take off the old one. Compare the length of the cables on the old vs new. If the old one is shorter than the new one, then it's broke off in the motor and you'll have to take apart the motor to get out the broken piece.
Here is the DIY if the length of the cable is the same:
http://rx300how2.home.comcast.net/~r...eplacement.htm
10 min fix if just swapping out
Here is the DIY if the need to retrieve the broken piece:
http://us.lexusownersclub.com/forums...howtopic=42394
1 hour fix if you need to get the broken piece from the motor
I've had to do this on mine, and I did it for a neighbor's RX300. Both times the cable was broke off inside the motor. Also, when you take the cable out, make note to which way the teeth are facing. I think they face toward the front of the vehicle.
Here is where I got the antenna for my neighbor: http://www.antennamastsrus.com/ I got mine when I was dumb about this stuff and spent $70. This place claims OEM antennas.
I remember when I had my lexus, and my old gf, ran it through the auto car wash and bent it, I ended up replacing the antenna myself, its not that hard of a job actually, me and a friend did it
Hope it works well for ya
