Go Back   Club Lexus Forums > Lexus Model Forums > RX Models > RX - First Generation
Sign in using an external account
Register Forgot Password?
Register Photos FAQ Members Calendar Search Today's Posts Mark Forums Read GarageUsed CarsVendors TSBs & Recalls
Welcome to Club Lexus!
Welcome to Club Lexus, the world's largest and most active online community of Lexus owners and enthusiasts.
You are currently viewing our forums as a guest, which gives you limited access to view most discussions and access our other features. By joining our community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join the Club Lexus community today (click here to register)!
Thread Tools Search this Thread Display Modes
Old 05-14-09, 12:30 PM   #1
sktn77a
Garage is empty, add now
Trader Score: (1)
sktn77a's Avatar
Default Timing belt pulley.............
More a vent than anything else......... had the timing belt replaced 18 months ago. Everything else was fine (cam seals, pulleys, water pump, etc). Took the car in today for squeaking belts and guess what -timing belt pulley!!! And just to cap it all off, the cam seals are leaking!!! Grrrrrrrrrrrrrrrrr!!!!!!!!!
Now, the $64,000 question. Do I change the water pump? No sign of any issues and the cost to replace it now ($462) is almost as much as to replace it on it's own ($600). I'm leaning towards rolling the dice on this one.
This ad is not displayed to registered members.
Register your free account today and become a member on Club Lexus!
__________________
Keith
2010 Toyota Prius
2008 Lexus IS250
2005 Toyota Prius
2001 BMW 530i
1999 Lexus RX300 AWD
sktn77a is offline   Reply With Quote
Old 05-14-09, 01:03 PM   #2
lexus114
Trader Score: (0)
lexus114's Avatar
Jeez Sk,that stinks!! I know I`d be ticked on that one!
__________________
2005 RX 330 AWD
2012 Mercedes-Benz C300 4 Matic Sport Sedan (wife`s car)
lexus114 is offline   Reply With Quote
Old 05-14-09, 06:14 PM   #3
blueridge
Trader Score: (0)
I'd do the pump. Ask about what they will knock off if you combine work. I'm taking mine in tomorrow morning for the timing/water pump and knock sensors. They knocked off $200 if I combined the knock sensors with the other work.
Toyota dealer
blueridge is offline   Reply With Quote
Old 05-14-09, 06:24 PM   #4
TEN-D'S
Trader Score: (0)
man up and do the pump...penny wise and pound foolish...go for it
TEN-D'S is offline   Reply With Quote
Old 05-14-09, 09:07 PM   #5
thomas1
Trader Score: (0)
thomas1's Avatar
The timing belt pulley? Is it worn? there are two idlers on the timing belt, and the water pump pulley.
__________________
1999 RX300
2008 RX400h
Moved up to hybrid land
super home mechanic
Borders, language, culture,God Bless America
Papa to 9, 7 girls, 2 boys
thomas1 is offline   Reply With Quote
Old 05-15-09, 12:10 AM   #6
salimshah
1999 Lexus RX
Trader Score: (0)
I am lost too. What is wrong with the pulley? Are we taling about the pulley on the crankshaft or up inthe valve train? Idlers can go bad due to lack of lubrication. They really need to be inspected.
I would suggest to replace idlers instead of water pump. I would replace the water pump if the coolant is other than Toyota/Lexus.
Salim
salimshah is offline   Reply With Quote
Old 05-15-09, 02:48 PM   #7
sktn77a
Trader Score: (1)
sktn77a's Avatar
Yes, both idler pulleys - bearings shot. Replaced both along with the cam seals and the accessory belts. The water pump was fine so, like I said, I'm rolling the dice on that one. Got it back and it's silent now.
I'm much more concerned about the transmission than the water pump!
__________________
Keith
2010 Toyota Prius
2008 Lexus IS250
2005 Toyota Prius
2001 BMW 530i
Old 05-15-09, 11:00 PM   #8
code58
Trader Score: (0)
Sktn- How many miles on your RX? Having replaced my DIL's (water pump, timing belt, and both idler pulleys) a couple or three months ago at about 130k mi., I can speak as to those parts because I cut them all apart with a die grinder and cut off blade to see what the actual condition was. I was astonished! The lower idler (one on the tensioner) was bone dry but smooth as silk. There was grease in the bearing but after that period of time, none ON the bearing. What grease there was (most of it was still there) was as live as new, not the least bit dried! It simply was pushed away from the ***** after all of that time. As a matter of fact I have no doubt that the bearing could have been regreased and put right back in service. (Yes, the bearings are "sealed" but extremely easy to remove the seal and replace with NO damage to the seal) I bought the pulley assy. new OEM (Koyo, exactly what came out of it) for $28.95 and already had the parts so no thought of reuseing the old. I DID NOT replace the parts because of noisy bearings, It was other concerns.
code58 is offline   Reply With Quote
Old 05-16-09, 02:46 AM   #9
artbuc
Trader Score: (0)
Quote:
Morning Roger! How long do you think that dry bearing would have lasted? Unless you repacked it, sounds like it would have failed pretty soon? almostwou
artbuc is online now   Reply With Quote
Old 05-16-09, 04:33 AM   #10
blueridge
Trader Score: (0)
Just got mine back from the Toyota dealer. The cam seals were just starting to leak but nothing bad so I went for the cheap insurance of changing them out. ($120)
When they ran it up we heard an odd noise but no CELs. They took it back down and found tensioner was bad. They replaced it for no charge on parts or labor!
Old 05-16-09, 10:30 AM   #11
sktn77a
Trader Score: (1)
sktn77a's Avatar
Blueridge: Where in NC are you located? I may try taking my car to the Toyota dealer in future. The lexus dealer charged $115 for each tensioner pulley, 400 for labor, and $300 for the cam seal replacement (said it would have been $800 if they were'nt already in there). Not sure how they came up with $460 to change the water pump while the car was torn apart.
I'm getting a little tired of being ripped off. I've paid between $1000 - $2000 every year for the last 5 years in repairs since the car went out of warranty. I mentioned the transmission problems to them and they said "there are no problems with the RX300 transmission and the dealership and Lexus wouldn't consider any "goodwill" because the car is so far out of warranty"!
My 2001 BMW 530i has only needed the water pump replace since it went out of warranty at 50,000 miles (it now has 100,000 miles on the clock). Wasn't cheap to repair ($600) but that's been it in the last 5 years. Interstingly, I had exactly the same experience with my 1992 525i (water pump and radiator were all that went out between 50,000 and 120,000). Pity they're making such butt-ugly cars today!
__________________
Keith
2010 Toyota Prius
2008 Lexus IS250
2005 Toyota Prius
2001 BMW 530i
Old 05-16-09, 01:53 PM   #12
blueridge
Trader Score: (0)
Huntersville, NC about 15 miles north of Charlotte. I paid $580 (out the door price) for their timing belt/water pump replacement service which includes all the other belts, and coolant.
I had random P0330 CEL's and had them change the knock sensors at the same time since the gave me a labor charge of $300+tax (usually more) since it was already there with major work. They allowed me to get the OEM parts elsewhere and I saved about $130 in this area.
Like I said above, they threw in the tensioner and extra labor when it was determined it was bad after putting it all back together again. They also showed my the cam seals during the first tear down and they were just barely seeping.
Not only was the Toyota dealer working to get my business, very helpful and obviously cheaper. But they are 2 miles from where I live versus a 45 min drive to the Lexus dealer. When I look at the fact they had this for 8 hours working on it, the entire top of the engine torn off, the passenger side of the engine torn out and still got out for about $1100...I'm impressed. The only up selling that took place was the cam seals that could have passed for longer but I'm really happy they showed me.
Old 05-16-09, 07:05 PM   #13
sktn77a
Trader Score: (1)
sktn77a's Avatar
Wow, I'm envious! The only Toyota dealer as close as my Lexus stealer is Mark Jacobson Toyota of Durham "and his dog Spot". Maybe I'll give them a try - I'm taking my son's Geo Prizm in there next week for a "Corolla timing belt replacement"!
__________________
Keith
2010 Toyota Prius
2008 Lexus IS250
2005 Toyota Prius
2001 BMW 530i
Old 05-16-09, 09:46 PM   #14
thomas1
Trader Score: (0)
thomas1's Avatar
Man, maybe I should fly out on your dime, enjoy some vacation, and fix your car for you. I would still probably be cheaper the Lexus dealership. I know I do excellent work, more than you can expect from the dealership....Just kidding, I do like NC more in the spring and winter though....
__________________
1999 RX300
2008 RX400h
super home mechanic
Old 05-17-09, 12:23 AM   #15
code58
Trader Score: (0)
Quote:
I wish I could answer that for you Artbuc. No way to know although I have always said and even moreso after I cut the removed parts apart, can say that I can't imagine finer parts than Toyota uses to build their cars. I mic'd the bearings with a digital mic (all the ***** used in the W/P and both idler pulleys are the same size) and they all mic'd EXACTLY the same. The ***** are all like a mirror, even under about 15-20 power magnification and under that magnification you can see the grind marks in the bearing troughs from manufacture but absolutely NO wear marks, even on the one that was bone dry. It looked no different except there was no grease on the actual ***** and trough. There was no sign of overheating in spite of that. I believe the reason that bearing (bottom idler) got dry is because it is a single bearing and the upper is a double bearing (2 of the same bearings in the pulley instead of 1). Because the upper idler was fully greased yet. W/P and both pulleys were absolutely smooth as silk yet.
Tags
2001, 250, 530i, belt, bmw, cost, huntersville, idler, labor, lexus, nc, pulley, removal, repair, replacement, timing
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Copyright © 2000-2008 Internet Brands, Inc. All Rights Reserved
Privacy Policy | Disclaimer | Terms of Service | JOBS
Get all contact info
Content Relevant URLs by vBSEO 3.5.2
