Axle Shaft ebay
rear Axle Shaft grease
hi,
what is the meaning of grease coming out of rear axle shaft?
if i am buying this part online, what is the best way to confirm that the part i am getting is the same? local firestone told me that i have to replace rear cv axle half shaft as there is a leak.
most of the online; pep boys have only front. none of them have rear.
does anyone know if its the same as below?
http://cgi.ebay.com/ebaymotors/99-03...lenotsupported
thanks
thanks
Last edited by kvramki; 05-03-09 at 08:15 PM. Reason: do not want to post another thread
hi,
thanks
thanks
Grease falling out, typically happens when the rubber boot has a rip.
Some unscrupulous shops [not all shops are unscrupulous] poke a screwdriver through the boot-hoses to generate work. A few times people run over loose plastic, which wraps around the boot and causes it to rip. A weak spot may rip too.
If the rip is detected early, one can repack the grease and put on a new boot, but if the grease runs out and dirt goes in, the joint gets ruined.
I would strongly suggest a boot repair, without removing the half shaft from the diff. If you remove the shaft from the diff, then you must replace the seals of the diff.
Salim
Salim
Last edited by salimshah; 05-04-09 at 09:27 PM. Reason: some word smithing to exhonorate good shops
