2000 rx 300 antenna
Old 02-12-10, 06:50 AM
  #31
sktn77a
sktn77a's Avatar
Do you have the link to where you got yours?
Old 02-12-10, 07:35 AM
  #32
bearbrew
bearbrew's Avatar
Default Antenna Mast Replacement
I do not have the link but here are a couple of links from a quick Google search. The first is the procedure for installing the new mast taken from the Lexus manual. The second is for a Toyota branded mast on Ebay.
It must make a difference on your location as the mast is a lot more expensive locally than some have stated for their locations.
Copy and paste the below links for easy access.
Bearbrew
http://rx300how2.home.comcast.net/~r...eplacement.htm
http://cgi.ebay.com/ebaymotors/ws/eB...d=350212278990
Old 02-12-10, 10:07 AM
  #33
98dohc
98dohc's Avatar
I wasn't going to buy one for another week or so, but since i found it again i just re-ordered another. This will be the 3rd one i've bought from the guy. No issue with any of them. They all work perfectly. I just have bad luck with things hitting them. The latest one was done in by a tree branch. Still works partiality, just doesn't retract fully.
http://cgi.ebay.com/Power-ANTENNA-MA...item5d27fcbee4
Old 02-12-10, 11:22 AM
  #34
bearbrew
bearbrew's Avatar
Default Antenna
A lack of lubrication on the mast itself can sometimes cause the antenna mast to hang up as it goes up or down. My antenna would not go all the way down and the silicone lube helped until the nylon rack broke off leaving about 4"'s inside the motor housing. I have had good luck wiping or spraying on some silicone based lubricant about twice a year. It seems to make the antenna operate easier. Operate the antenna a few times and wipe off the excess.
This won't fix a gear set that has the white grease all gummed up but will let the mast work more freely.
Bearbrew
Old 03-31-10, 05:47 PM
  #35
preston805
preston805's Avatar
I am new to the club and have a 2001 Rx300. I am sick of the whole power antenna thing as I have replaced the mast three times in the last year. Yes, I have been purchasing after market masts and now know this was a mistake. However, the last one I bought was advertised as OEM original Lexus part and I assumed this was true even though I wasn't buying directly from a Lexus dealer. This one did not break in the usual way. At the top end of the long plastic part that inserts in the motor there is a metal crimp. This crimp is on the inside top of the antenna and holds the plastic to the antenna. Well, the crimp pulled loose and sucked the entire plastic piece into the motor.
My question is has anyone out there switched to one of the short roof-top antennas, like Lexus uses on the RX400? If so, can I simply buy one of those, drill a hole in the roof and extend the antenna cable up to it and hook it up? Are there other parts needed to make this switch a success? I read somewhere that there may be an amplifier??? I am not sure if they were talking about the stereo in the dash or if there is some sort of additional amplifier for this type of short antenna.
I realize this will take some care and finesse but before I go buying parts and drilling holes in my car I'd like to know if it would even work.
Old 04-01-10, 05:45 AM
  #36
bob2200
bob2200's Avatar
Originally Posted by preston805
My question is has anyone out there switched to one of the short roof-top antennas, ..... can I simply buy one of those, drill a hole in the roof and extend the antenna cable up to it and hook it up?
I think the easiest way to go is to just get a junk-yard RX300 antenna. They normally last for years and years, in my observation. However, I have put a rooftop XM Satellite Radio antenna on my RX300 and routed the cable down to the radio area. I did a writeup on this forum about 1 1/2 years ago. Routing the cable was not that difficult (but I do have experience in these things as an amateur)
As to the need for an RF (radio frequency) amplifier. You will get less signal strength from a short antanna. This will likely be good enough for local stations. It all depends on whether you want to receive those weaker stations.
Old 04-02-10, 04:49 PM
  #37
preston805
preston805's Avatar
Thanks, that makes sense about the RF amplifier. This helps me in making up my mind as to the direction I will go. Does the RF amplifier need a power source?
Old 04-02-10, 05:45 PM
  #38
bob2200
bob2200's Avatar
For sure, an RF amplifier needs power (12v DC). There is plenty of 12v DC power around the radio area and elsewhere in the car. You would want to use 12v DC that is only powered on when the car or radio is in operation (i.e., not on all the time)
Old 08-16-10, 12:39 AM
  #39
Tondar
Tondar's Avatar
Does anybody know the length of the cord? I lost the original one and need to cut the replacement.
Old 09-09-10, 08:34 AM
  #40
MLEE4984
MLEE4984's Avatar
Sorry to bring ths thread back from the dead, my antenna is making clicking noises, it goes up and down fine at the moment. Would you guys say that it's the motor or the mast itself?
Thanks in advance,
-Mike
Old 09-09-10, 09:25 AM
  #41
salimshah
salimshah's Avatar
Thanks in advance,
-Mike
Try cleaning and lubing and cleaning the mast. Typically it is noisy as it is pulled back in when you turn off the engine.
Salim
Old 09-09-10, 10:11 AM
  #42
MLEE4984
MLEE4984's Avatar
What type of lube would you use?
Old 09-09-10, 12:52 PM
  #43
salimshah
salimshah's Avatar
I would say any, but remember to clean it out as the the lube will attract dirt. My favorite is lubriplate, others have used teflon based lube.
Salim
Old 04-09-11, 02:17 PM
  #44
sktn77a
sktn77a's Avatar
Well, here it is almost 2 years after I bought the replacement mast on e-bay for my noisy RX300 antenna. The grinding noise on went away after I bought it so, of course, I didn't bother to replace it. Bad move on my part! Last week my son says "the antenna won't go up or down any more". The toothed belt had broken inside the antennal motor mechanism. I really wasn't looking forward to tearing apart the rear interior trim again, like when I replaced the towing module and wiring. However when I called my trusty Lexus dealer he wanted $600 to replace the entire antenna (they don't replace just the mast), $300 for the antenna and $300 labor!
So I followed Gazi's instruction on this post and everything went together without a hitch. Took me about 2 hours including taking the antenna motor assembly apart and removing the broken part of the belt. It's working now although it makes a faint grinding noise when it's fully retracted. I'm guessing it'll be fine.
Old 05-18-11, 02:28 PM
  #45
Mark2008
Mark2008's Avatar
Talking Power Antenna Mast Replacement
Originally Posted by gazi001
I found that this topic was well covered but fragmented. Also there were no complete instructions as to how to get to the motor.
So here goes...
You may need to completely replace the antenna motor on your RX300, or if you are lucky, only the long flexible nylon rack of the antenna itself is broken. Usually if the antenna will not retract fully, it means the antenna rack is damaged or broken. If the rack is broken off, the motor will need to come out to get at the broken part.
You will need a pair of needle-nosed pliers, a long-handled medium flat screwdriver, a small flat screwdriver, a Phillips crosshead screwdriver, a 10mm spanner and a 12mm spanner.
You may get away with replacing the antenna by unscrewing the chromium-plated nut that secures it on the outside. I used a pair of needle-node pliers to turn it, and once it was loose, a long-handle screwdriver on one side only was sufficient to turn it. It took a while as the thread on the nut is deep. Be patient. Once you have it off, you can pull the antenna straight up. If it's all there, just worn, simply replace it, using the antenna installation instructions at the end of this article. If it is broken off, read on…
Remove the external plastic trim piece that was held down by the antenna nut. Go inside the car, remove the rear deck carpet and the removable strut that contains the rollout luggage cover, and fold down the right-hand rear seat.
The key part you will need to move in order to get at the motor is the vertical carpeted wheel arch panel on the right side of the luggage compartment. Note, you will NOT need to remove any of the trim around the window. Remove the little door in this panel that normally conceals the first aid kit.
Go to the very front of the rear deck and pull up firmly on each the five popup fasteners that hold the front edge of the hinged deck that covers the spare wheel. Underneath you will find two 12mm bolts that hold the hinges. Remove these and the deck comes out. Remove the tool tray and covers.
Many of the fasteners you will have to remove are of the press-in-pop-out plastic type. The black ones have a slot in the top, into which a small screwdriver can be inserted horizontally. If you do this and then use another screwdriver as a levering point, these fasteners come out very easily.
Using this technique, pop up the fasteners that attach the plastic moulding that runs across the bottom of the doorway, and has the door latch coming through it. There are four black fasteners visible on the inside. Be sure not to lose these fasteners, as they tend to fly out and travel quite some distance. Underneath there are six more fixed fasteners hidden. Do not be afraid to pull firmly.
Similarly pry out the fasteners that hold the right-hand black storage bin. There is an additional screw-in one in the floor of the bin. Remove the bin.
Remove the two 10mm screws holding the black luggage tie-down rings at right front and right rear of the compartment.
Pry up and remove the plastic cover on the top of the right hand interior wheel arch.
Your next target is the L-shaped moulding at the lower right of the rear doorway. There are two black pop fasteners at the bottom, and a couple more hidden ones at the top.
You now have a good view of the carpeted moulding and its attachments, two fasteners in the vertical part at the rear, and one mounted horizontally at the front. Remove the two at the rear first, then go inside the right rear door and pry out the one at the front corner.
Carefully pull the fastener at the top inside corner of the large plastic moulding on the front of the wheel well, the one that has the seat belt tidy clip attached to it. This is the only action you need to take on this moulding, leave the rest of it untouched.
You now have enough fasteners removed to pull out the carpeted panel far enough for you to be able to reach the antenna motor easily. From the back edge, push down on the top and pull to the left at the same time. It should hinge from the front fairly easily without detaching completely. I used a short piece of 2x4 to wedge in there to hold the moulding open.
There are two 10mm nuts holding the antenna motor in place. Remove them and pull the motor out. As soon as you can reach it, detach the antenna cable from the radio (at the top of the motor) and pull out the drain pipe from the bottom of the wheel well, leaving the pipe attached to the motor.
Now all you have left is the electrical connection. On one side of the white plug is a tab, which you need to press in with a screwdriver or other suitable tool, and the plug should come out easily. If it doesn't come out easily you are not pressing hard enough on the tab.
Now you have the motor in your hands.
Unscrew and remove the support bracket, noting where the ground wire is attached..
Unscrew the screws holding on the casing of the motor, and CAREFULLY separate the two halves of the case, holding the main body underneath.
Inside this casing there is a small quantity of grease for lubricating the mechanism, so try not to get it spread everywhere.
Lift up the circular plastic rack storage can, and inspect its inside. You may find a broken piece of the toothed nylon antenna extension rack coiled up in there. This may be the root of your original antenna problem. Remove and discard it.
Take a look at the open mechanism. Notice the path from where the antenna emerges, down into the mechanism. On the underside of the white circular plate are the teeth that drive the rack. When installing the new antenna, you will need to insert it correctly relative to where these teeth are.
Replace the storage can, reinstall the motor cover and screws, and the support bracket, together with the ground wire.
Now it's time to put it all back together again.
Hold the motor close to where it installs, and in the correct orientation, but before you fix it in place, make sure you reattach the signal cable from the radio, and the power hookup, and reinsert the drain pipe through the hole in the wheel well.
Carefully slide the motor back to its correct location and loosely reattach the two 10mm nuts. Make sure the exit hole of the antenna is correctly located relative to the hole in the bodywork before you tighten the nuts.
Do not be tempted to replace all the panels just yet.
Here is where you rejoin if you do not need to get at the motor.
It helps if you have a friend or SO available to help. Ask him/her to turn the ignition key to the radio-only position, and turn on the radio. You should hear the motor start to operate. It will keep running for a while until it times out. Wait until it stops. The mechanism is now in "antenna up" mode.
Take your new antenna and fully uncoil the rack, making sure you remove all the twist ties it came with from the factory.
Fully extend the telescopic metal part of the antenna as far as it will go, drawing the rack into the metal tubing. With the rack teeth facing FORWARD, insert the end of the rack into the antenna hole where it emerges from the bodywork. You may need to wiggle it until most of the rack that is still showing goes in, at least six inches or more, at which point it will go no further. It should not require any force.
Holding the antenna directly vertical above the hole, ask your friend/SO to turn the radio OFF. The motor will start the mechanism to retract the antenna. If you have inserted it far enough, and it is facing in the right direction, the mechanism will take hold of the end of the rack and draw it entirely into a tight coil in the circular cup inside the motor. As it draws in, guide the metal part of the bottom of the antenna into the motor body in the correct way. The antenna should withdraw completely as it used to.
Reinstall the black plastic trim moulding from the outside, and screw the chromium-plated nut back fully down on the antenna.
Have your friend/SO turn the radio on and off several times, waiting each time for the mechanism to cycle completely. The antenna should fully extend when the radio is switched on, and fully retract when it is switched off.
If you were just replacing the antenna mast itself, you're done.
For the rest of you, it's time to tidy up.
Carefully push the carpeted side panel back into its correct position, replace the wheel arch top plate and pop in the single brown fastener on the front side of the wheel arch.
TIP: At this point, the order in which the rest of the parts go back is not obvious, so when you insert one of the black pop-up fasteners, only insert it very loosely, in case you need to remove it again to attach something else to the same hole.
Reinstall the plastic cover over the spare wheel, the side bin (with its nut at the bottom holding it down), the L-shaped piece at bottom right of the door opening, and the moulding across the bottom of the tailgate door opening, with the several hidden fasteners and the four black ones.
ONLY when you have everything back in place, should you go round and fully press in the black pop-up fasteners.
Reinstall the luggage tie-down loops with the 10mm bolts.
Reinstall the rear compartment deck by reattaching the hinges with the 12mm bolts, and pop back the fasteners on the hinged trim piece.
Put back the first aid kit door.
Finished.
Enjoy. (Courtesy of truebr1t of US Lexus Owners Club)
The Gazi001 description is spot-on and thorough, and I wanted to add a few notes I took yesterday while replacing my RX300 (vintage 2000 and on its third transmission...another thread but not here) antenna mast. I removed the slotted chromed nut holding the antenna mast in place by using a very dull, half inch wide screwdriver blade, and taping against each of the four slots using a hammer with the dull screwdriver blade. The nut came off easily and the remains of the antenna and its toothed drive plastic were readily removed. I did not need to remove the hinged rear deck that covers the spare tire, but did prop up the hinged floor, and did remove one of the large push pins that holds down the hinged flap and the smaller panel push pin nearby.
There is a plastic hook attached the underside of the hinged deck, and this I used to hold the side panel out of my work area. I suspect this hook is used specifically to hold the panel when servicing the antenna power unit, since it cannot be hooked to anything else nearby. Rather than remove the drain tube from the wheel well, I cut a slot in a shallow cardboard box for the drain tube and worked on the motor while still attached to the drain tube.
Removed the power assembly screws and the broken end of the toothed plastic actuator; cleaned the two large drive gears, applied fresh Aeroshell lube to these two gears, and completed the reassembly. The antenna channel conduit is inserted before the power cable is reattached, due to the short length of this cable. Antenna cable is reattached, along with the power plug. Loosely mounted the motor assembly and reattached same using the two 10 mm screws.
Purchased the OEM replacement antenna mast from antennamastsrus.com ($29.50 including shipping) for P/N 86337-0W030 showing on the invoice. The actual parts bag listed P/N 86300-0W010-B (Mexico). Threaded the toothed actuator plastic lead into the antenna housing. One needs be a little aggressive in pushing this lead to begin engaging the teeth of the drive gears, as there is a small ridge the end of the toothed lead must be "bumped over" just upstream from becoming engaged by the takeup gear. A good brisk thrust of this plastic lead should get it beyond this hang-up and engaged, while the significant other turns off the radio. The interior panels do not need to be removed if the drive lead is fully intact, with no broken parts left in the takeup reel on the motor. Tech Service (Tech@AntennaMastsRus.com) responded quickly to my installation inquiries and installation instructions are provided on the back of the sales invoice. Phone support is found at 920-686-0644 or -9688. I will upload some pictures that may help the next soul needing to replace the mast.
Attached Thumbnails 2000 rx 300 antenna-p1010035.jpg   2000 rx 300 antenna-p1010037.jpg   2000 rx 300 antenna-p1010039.jpg   2000 rx 300 antenna-p1010041.jpg   2000 rx 300 antenna-p1010043.jpg
Quick Reply: 2000 rx 300 antenna
