Go Back   Club Lexus Forums > Lexus Model Forums > RX Models > RX - First Generation
Sign in using an external account
Register Forgot Password?
Register Photos FAQ Members Calendar Search Today's Posts Mark Forums Read GarageUsed CarsVendors TSBs & Recalls
Welcome to Club Lexus!
Welcome to Club Lexus, the world's largest and most active online community of Lexus owners and enthusiasts.
You are currently viewing our forums as a guest, which gives you limited access to view most discussions and access our other features. By joining our community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join the Club Lexus community today (click here to register)!
Thread Tools Search this Thread Display Modes
Old 03-09-09, 05:33 PM   #1
MS99RX300
Garage is empty, add now
Trader Score: (0)
Default Some service questions
Hello everyone, i am due for my 75000 mile maintainence.
Also, i believe that the front brakes need to be changed.
I was hoping to try and get the brakes done elsewhere, since the rates at the dealership are astronomical.
Does anybody have any suggestions?
I do not believe that there are any "indie" shops for lexus in my immediate area.
I was thinking maybe meineke, midas, NAPA, etc.? Or should i just pay some more and have it done at the dealership and save myself some peace of mind?
Also, What all is included in the 75K service and approximately how much will it cost?
Thanks for your time!
This ad is not displayed to registered members.
Register your free account today and become a member on Club Lexus!
MS99RX300 is offline   Reply With Quote
Old 03-09-09, 06:44 PM   #2
AlexusAnja
2010 Acura MDX
My Garage
Trader Score: (0)
AlexusAnja's Avatar
Not sure, but 75K I don't believe is the "major" one, but the 60K is the big one, which was timing belt (with waterpump, which dealer will suggest), spark plugs, antifreeze, brake fluid, rear diff. fluid, and oil change plus all filters. I believe the 60K maintenace is $1600 at dealership. If you did not have these done at 60K, the dealer will want to do these.
As for REAL maintenance times for items, go with:
100K for timing belt and water pump if necessary
100K for spark plugs
60K for brake fluids if they look dark or you feel braking softness
35K-40K for brake pads, depending on how you drive, could be as little as 25K.
20K tops for air filter
3K for oil change
60K for rear diff
50K for transmission drain and fill
I can't think of anything else as a "maintenance" thing. I'm sure others can jump in with some other items.
As for brakes, if you can't do yourself, then I would say a reputable brake shop is good. The RX300 is not a sophisicated braking system and should run about $100-150/pair at a brake shop or Pepboys as such.
__________________
'10 MDX blk/blk
'04 LS430 CL blk/blk (I'm on cloud 9)
'99 RX green/beige - (still smashing, but it's the beater)
N:Quebec E:Boston W:Chicago S: Orlando
AlexusAnja is offline   Reply With Quote
Old 03-09-09, 07:18 PM   #3
MS99RX300
Trader Score: (0)
hmm the dealer didnt ask for the timing belt for 60K, however, could be happening for the 75K i guess...could vary dealer to dealer?
As for the brakes, i cannot do it myself(need more tools) and i usually have car work done at the dealer, except state inspections and emissions, so getting true work done at a little shop is still seems a little iffy to me...however, getting ripped off at the stealership sucks too.
Doesn't help my confidence that a friend had his toyota minivan fixed at the local Meineke and one of his rims was SERIOUSLY bent...
Old 03-09-09, 08:54 PM   #4
carguy07
Trader Score: (0)
carguy07's Avatar
Brakes are very easy, any competent shop can do them with no issues.
Or use your brake replacement budget to buy the tools. You only need 2 wrenches (12mm & 14mm I think) and a C-clamp. A floor jack with jack stands would be nice too but not necessary. Call a buddy that has done a few brake jobs before, get a 12 pack of bud and you will be done in less than 1 hour. If your rotors are in good shape you could be on your 3rd beer and only out $50. IMO
carguy07 is offline   Reply With Quote
Old 03-10-09, 12:08 AM   #5
code58
Trader Score: (0)
Timing belt, W/P, idler pulleys are all at 90k on an RX, but trust me, I've changed them, as have many others here and they are of such high quality they will probably go twice that. Everything I took off at over 100k looked like new.
code58 is offline   Reply With Quote
Old 03-10-09, 06:54 AM   #6
lexus114
Trader Score: (0)
lexus114's Avatar
3K for oil change
60K for rear diff
timing belt @ 60,000 miles??
__________________
2005 RX 330 AWD
2012 Mercedes-Benz C300 4 Matic Sport Sedan (wife`s car)
lexus114 is offline   Reply With Quote
Old 03-10-09, 07:29 AM   #7
UNOHOO
2003 Lexus IS
My Garage
Trader Score: (3)
UNOHOO's Avatar
Send a message via AIM to UNOHOO
a lot of the maintenance is also personal preference, for example heres my schedule:
every 3k miles - oil change even though i do use synthetic
every other oil change air filter - i have K&N so i just clean it
every other oil change tire rotation
every other oil change drain and fill for the transmission
on top of that just monitor everything else and do it as needed
UNOHOO is offline   Reply With Quote
Old 03-10-09, 07:42 AM   #8
mikey00
Trader Score: (0)
You need to have a serious talk with your dealer. He is taking you for a ride. Timing belt isn't due to 90K and it's even debatable if it's needed then. Spark plugs are not due to 120K. Mine came out at 125K looking like new. Rear diff fluid is lifetime fluid. All these are per Lexus owners manual. Rear diff fluid is the only one I might consider changing. It's cheap and can't hurt. I still have my original fluid at 150K but I know others recommend changing it.
mikey00 is offline   Reply With Quote
Old 03-10-09, 07:55 AM   #9
vanguy
Trader Score: (0)
Agree with Lexus114, timing belt and spark plugs can go way over 100K miles. I would change out all the fluids: oil, rad, brakes, transmission, tranaxles (if AWD), and replace engine, oil, and cabin filters. Check the air pressure, wash the car inside out, give it a good wax and you feel like you have a new car again.
vanguy is offline   Reply With Quote
Old 03-10-09, 09:01 AM   #10
lexus114
Trader Score: (0)
lexus114's Avatar
unohoo my boy,we gota talk,as your friend,lets look at some things you may be doing wrong here.1st- if your changing your oil @ 3k intervals on synthetic,your wasting money.the main reason synthetic is even needed is for an extended drain interval,and extreme cold.if your going to stay on a 3k oci, i recommend a good conventional oil. i.e pennzoil,quakerstate,exxon superflo.
2nd- every time you clean a k&n air filter,you reduce its efficency.(i know its spelled wrong) i would recommend once every two years.(check it on a yearly basis though) just these recommendations will save you time,money,and you will still have your piece of mind.
as far as the other two,i believe your on the right track.
__________________
2005 RX 330 AWD
Old 03-10-09, 12:25 PM   #11
UNOHOO
2003 Lexus IS
My Garage
Trader Score: (3)
UNOHOO's Avatar
well the oil i know is overkill but i like doing it that often just to keep it nice and clean, not to mention once i switched to synthetic it seemed to run smoother and better, maybe its just psychological but hey it cant hurt to change it out that much, besides whats 30 bucks every 3k miles?
and the air filter i figured it would degrade after awhile, i didnt know any specs on how long to keep it so i had just kinda planned on keeping it a year or so before replacing
Old 03-10-09, 12:28 PM   #12
UNOHOO
2003 Lexus IS
My Garage
Trader Score: (3)
UNOHOO's Avatar
either that or once ive used up the k&n air filter cleaning kit (change it out for a new one)
Old 03-10-09, 02:07 PM   #13
sktn77a
Trader Score: (1)
sktn77a's Avatar
The Lexus dealership is not the place to get a "brake job" - they will charge you twice what any other reliable repair facility will. Try your local Toyota dealer first or any brake/muffler specialist. You will need new pads and possibly the rotors turned.
If you've been a really bad boy/girl, you may need the rotors replaced
__________________
Keith
2010 Toyota Prius
2008 Lexus IS250
2005 Toyota Prius
2001 BMW 530i
1999 Lexus RX300 AWD
sktn77a is offline   Reply With Quote
Old 03-10-09, 02:51 PM   #14
UNOHOO
2003 Lexus IS
My Garage
Trader Score: (3)
UNOHOO's Avatar
honestly the brakes are really easy to do yourself if you wanna save even more loot
Old 03-10-09, 02:53 PM   #15
lexus114
Trader Score: (0)
lexus114's Avatar
thats true,their a piece of cake.......and milk too!
__________________
2005 RX 330 AWD
Tags
2002, 75k, lexus, rx300, service
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Copyright © 2000-2008 Internet Brands, Inc. All Rights Reserved
Privacy Policy | Disclaimer | Terms of Service | JOBS
Get all contact info
Content Relevant URLs by vBSEO 3.5.2
