Old 12-15-14, 04:42 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Exterior Guides
Print Wikipost
Drivers side window control replacement
Old 09-02-13, 06:13 PM
RXit
RXit's Avatar
Very good detail in the photos, thank you, a big help. I have a rear window that opens every time I start the car and the master at the drivers door doesn't work for that window. I will disassemble as described and post the results. Thanks.
Old 09-06-13, 09:17 AM
gypsyboots
gypsyboots's Avatar
Default 2001 rx300/window switch
how would I change an automatic window switch ?
Old 09-06-13, 11:00 AM
gypsyboots
gypsyboots's Avatar
cotteng-thanks, your explanation and pictures are perfect. I will give it a try when I have some time.
Old 09-14-13, 08:41 AM
jryan
jryan's Avatar
I just bought a 2002 rx300 the other day. Today my driver side window did some really strange behavior similar to what you're describing. When I pushed the window down button it went both up and down a few times. I let it calm down and it returned to normal.
Did anyone else have luck with cleaning the device? A can of compressed air and 15 minutes sounds a lot cheaper than the other solutions.
Old 09-16-13, 06:09 AM
jryan
jryan's Avatar
I fully disassembled and cleaned the part this weekend to no avail. I believe it is the failing relay on the board. Not the best at soldering so it looks like this will be an ebay purchase.
Before I do, does anyone know if there are any other p/n's that are a direct swap out for this module? I know many toyota parts fit on the lexus.
Old 09-18-13, 07:22 AM
gypsyboots
gypsyboots's Avatar
Cleaning the control to the automatic window worked for me I wish I had something else I could add. Good luck to you
Old 09-18-13, 01:41 PM
HadYurPhil
HadYurPhil's Avatar
The large relay on the circuit board controls the window's direction. Mine was acting horribly until I replaced that relay. It's out there... Just google the numbers on it.
Old 09-23-13, 08:24 AM
jryan
jryan's Avatar
Picked up the part from a person who was parting out their rx300. Problem solved.
Old 09-05-14, 03:39 AM
fromxtor
fromxtor's Avatar
Dont mean to necro this thread, but the actual rocker switch broke off on my master panel. The whit pegs still allow the window to work. So I just need to buy a used switch and swap out the rocker portion?
Old 04-24-15, 01:52 PM
skipilot9
skipilot9's Avatar
Default RX 300; Driver Side window control circuit Board Replacement
Can anybody confirm whether I can replace the the driver side window control circuit board without effecting the remote key entry system. Where is the receiver for the remote key entry located? Thanks.
Old 04-24-15, 07:42 PM
mizak82
mizak82's Avatar
i swapped mine out with zero issue with the keyless entry...
cwsteini
12-10-16 06:33 PM
edgy
15
12-29-15 08:11 PM
mb001
10-10-14 08:37 AM
KelsoTrack
10-18-11 07:10 AM
ndbethy
12-01-09 08:27 PM
Quick Reply: Drivers side window control replacement
