Freaking out!!! Cel codes $985.00 repair!
Old 02-19-09, 07:56 AM
  #31
lexus114
lexus114's Avatar
I wonder if it`s the fuel pump going bad? or fuel pressure regulator?
Old 02-19-09, 08:26 AM
  #32
zombie
zombie's Avatar
you can save yourself the labor cost of installing the o2 sensors and do it yourself. its not that hard. changing out the spark plugs is more difficult then the sensors. i changed mine out.
Old 02-19-09, 09:22 AM
  #33
salimshah
salimshah's Avatar
My guess, is fuel starvation .. could be due to cold ... there should be a hot water circulation near the air mixer (works only after the engine block warms up). Also the fuel pump may be acting up due to severe cold. A flow test as well as pressure test of the gas delivery system would verify (in same cold conditions).
Dealer may be the best bet (may cost you more but the hopefully their experience pays off. Other shops may charge you less /hr rate but may take more hours to fix/diagnose)
Salim
beachlover
02-28-20 09:55 PM
lillexrx
12
11-28-09 11:30 PM
gsowner88
GS - 1st Gen (1993-1997)
06-10-08 09:08 PM
SHY820424
05-02-08 05:50 AM
Quick Reply: Freaking out!!! Cel codes $985.00 repair!
