Will RX330 stock wheels fit my RX300?
Old 12-04-08, 08:51 AM
jaxrwld
jaxrwld's Avatar
Default Will RX330 stock wheels fit my RX300?
Does anybody know if the stock RX330 (17 or 18 inch) wheels and tires will fit an 02 RX300???
Old 12-04-08, 01:44 PM
sktn77a
sktn77a's Avatar
Yes, they will. Most wheels are interchangeable between the two but a couple of aftermarket are a little iffy.
Old 12-05-08, 06:04 AM
alaskaty
alaskaty's Avatar
a handfull of people have put the 18's from an RX330 on their RX300's with no problems. I have a set that I'll be getting mounted and balanced pretty soon.
Old 12-06-08, 04:10 PM
Nickv
Nickv's Avatar
Default Change to RX330 wheels
So going to 18" wheels from an RX330 onto a 2000 RX300 will result in the same diamater of tires? And not change the calibration/accuracy of the speedometer?
Thanks for info.
Nick
Old 12-10-08, 03:23 PM
StrmRdr23
StrmRdr23's Avatar
Thanks for info.
Nick
you just need to run the correct size tires to maintain correct rolling diameter. i have the graphite rx400h rims as my winter wheels for my 2000 rx300. i'll take a look to see what size tires i'm running.
Old 12-11-08, 01:11 PM
alaskaty
alaskaty's Avatar
I just put them on my wife's RX300 and we're having no issues whatsoever. They don't need spacers or any additional hardware, just get the tire size that keeps the stock wheel diameter.
Old 02-11-09, 05:30 PM
SethP
SethP's Avatar
Okay, just to clarify - 225/65R17 tires on a 17" lexus oe rim will work on the RX300 replacing the 16" rim w/ P225/70R16 tires?
Just want to make sure the larger rim with the same tire diameter doesn't equal a larger wheel (rim & tire combined)
Old 02-12-09, 01:59 PM
alaskaty
alaskaty's Avatar
I went from stock tires (225/70R/16) to RX330 rims and tires (235/55R/18) and now according to tiresizecalculator my speedo reads 0.8% too fast (so when my speedo reeds 60mpg I'm only traveling at 59.5mph)
Old 02-12-09, 04:07 PM
sktn77a
sktn77a's Avatar
Yes.
http://www.miata.net/garage/tirecalcold.html
DavidinCT
12
10-03-07 12:59 PM
SCM3
11-29-04 04:42 AM
mek88
Wheels and Tires Classifieds
03-17-04 03:25 PM
Quick Reply: Will RX330 stock wheels fit my RX300?
