Please HELP! Just purchased 99 RX300, ECT/SNOW Light Dead
Hi all, I would really appreciate anyone who can help. I just purchased my first lexus, a 1999 Rx300 and after purchasing it I realized that the "ECT/SNOW" light doesn't light up in the instrument cluster. I've searched and cannot find any pics of dashes. So I ask if someone here can take a picture of their instrument cluster with the "ECT" on and another pic with it on with "snow mode".
I read the other forums on how to remove and replace the bulbs for the "D" light (mines out as well) but I just really need to know if there is just one light bulb for the "ECT/SNOW" or are there two? Also is the color green or amber or what? So if anyone can help I'd greatly appreciate it! THANKS!
Ok, just got finished speaking to Kuni Lexus, and they said that the replacement bulb for the "ECT/SNOW" bulb is part number #83101-04020. So I'm assuming there is only one bulb? Isn't there a "ECT" light and "Snow" light that lights up on the instrument cluster?
ECT/Snow
Just purchased 99 Harrier. Fwd 2.2L Engine. Dont have PWR option on mine. Only ECT/Snow. Took some pix while ON. As per previous threads, I gathered that it only starts in 2nd Gear to prevent wheel spin. However since we have warm winters, does it affect the driving if kept on on normal tarred/off road tracks?
Super Moderator
I am not 100% sure about the part number offhand. I do know that from recent experience that Lexus would have the parts diagram up on their computer to pinpoint the precise bulb. I was looking at another diagram I saw recently, and I think it might be the following:
90099-53009
83101-14040
I'll remind everyone. The service manual that several of us have rarely has the part numbers that we usually need. It is a separate diagram that Lexus has.
90099-53009
83101-14040
Super Moderator
You probably won't notice much difference when using SNOW on the offroad tracks. I particularly use it on the rainy days we get here in Miami just for better control and particularly when I was back in Mexico on the expressways, where the potential for the oil and water mixing on the road was more so than on U.S. roads and any type of traction control was a must down there.
Why would the ECT SNOW bulb burn out, it's not used that often...
Does the system indeed "work"? If you are in D at rest, then press the Snow button and accelerate so slightly, do you notice the transmission seeming to work a little harder? All it does is start you in 2nd so you don't "spin-out" when accelerating when you're stuck in snow etc.
My guess is a faulty switch/fuse. The probability of the bulb burning out is pretty slim for it's limited use. It's the same bulb all the pilot lights use in the cluster. Places like autozone etc will have them...
Check to see if indeed the system is even working first before you pull your cluster out.
Ok, will have to give it a try first then. It is a bit suspicious now that I think about it that both the "ECT Power" and "ECT Snow" lights are out.
could it be a fuse or relay?
Yeah, "ECT/POWER" and "ECT/SNOW" works, so I'm gonna be ordering the light bulbs from Irontoad.com.
Instrument Light Bulb for: "D" (Drive) Light (part#83119-24670)
and "ECT/SNOW" & "ECT/POWER" Light (part#83101-04020) (both same bulb, speedo has different colored lenses for each, "green and orange")
Super Moderator
Hi again, ok I just received my new light bulbs from Irontoad.com, Ryan gave me two extra sockets for free for the "ECT" light bulbs. The light bulbs themselves were fairly inexpensive the "ECT/Power" and "ECT/Snow" light bulbs were the same bulbs, priced at $2.08 (83101-04020) and I order a "D" light bulb priced at $4.07 (83119-24670). Shipping was the most expensive at $9.99 for orders under $50(I think). I also received the bulbs fairly, It was confirmed shipped last Thursday and I received it today.
Anyways, I changed the "D" light bulb and it worked! Then I noticed that my "P" (Park) light went out! So now I gotta order another light bulb. Also when I changed out the "ECT/Power" and "ECT/Snow" light bulbs their still dead and not working! Anyone have any idea what might cause this? I switched the light bulbs around with the "seat belt light bulb" and it worked so I know the new bulbs I received are working. Anyone know if it could possibly be a fuse or relay or something? Any help would be greatly appreciated. THANKS!
Sorry to bring back a 2 year old thread. But did you find a resolution to this issue? I have the same problem with my GS 400. Pressing the rocker switch for power or snow ect does not activate the dash light. Thanks.
