Considering to put 19" on RX300 -- any ideas? suggestions? thanks...
Old 01-25-02, 08:32 PM
hleo1
hleo1's Avatar
Default Considering to put 19" on RX300 -- any ideas? suggestions? thanks...
Hi,
I'm seriously thinking of putting a set of 19" on my RX300. Maybe 19x8 or 19x8.5, with tires 255/50/19 Michelin tires. I don't want to go any bigger (although I love big rims), 'cause the tires get thinner...
I have a few selections in mind for the wheels... either the Dronell type M05 or the Lowenhart LD1 (silver with chrome lips).
I may also consider TEIN coilovers just to lower the ride a little little bit.
What do you all think? Do you think my ride will be rough? not comfortable anymore? too stiff? Advice, comments, suggestions please...
thank you very much!
Hendry
Old 01-25-02, 10:04 PM
sleepybobcat
Registered User
sleepybobcat's Avatar
19" would look cool, but make sure the rear tires
have enough clearance with the rear struts!!! (spacer may be needed)
Old 01-25-02, 10:18 PM
Swing913
Swing913's Avatar
where can u get TEIN Coilovers??
Old 01-26-02, 06:05 AM
Shonuff
Shonuff's Avatar
if you go 19 x8 or 8.5 you will need spacers....possibly for all four wheels, but definately in the rear. with that size tire on a 19 you will also rub inside the front fenders at full turn.
i have 18 x7.5 +38 offset with 255/55 and i needed spacers on the back wheels. the front tires also barely rub at full turn.
if you lower it this could make the situation a little worse unless you drop your tire size.
Old 01-26-02, 07:46 AM
MrSypher
MrSypher's Avatar
Hleo, I am also looking into 19's for my RX.. You really don't want to go that wide the max width to do would be 7.5" don't go any wider than that. Here are the rims I am looking into. They have a nice size lip and rim is beautiful....
Old 01-26-02, 10:37 AM
hleo1
hleo1's Avatar
Default Spacers... where can I get them? which ones?
What size spacers will I need? My main priority for tire size is that I want thicker tires, not the very low profile, that's why I wanted to get the 255/50 series...
Old 01-26-02, 10:41 AM
leebro3
leebro3's Avatar
Hleo1,
I put 19x8 Ziet R wheels by Bridgestone Japan on my RX300. Originally, I put the 255/50-19 Michelin Diamaris (Exact tires on the front wheels for the BMW X5 sports package with the 19 inch wheels) on my truck. The front wheels and tires rubbed at full turn on the front wheels and the back wheels rubbed on top of the fender and on the inside (spacers will definitely be needed). Plus, when I did put them on, the car looked like a offroading vehicle so if this is your plan, I would definitely recommend putting some lowering springs on your RX. I eventually went with a lower profile tire, 245/40-19 and I plan on lowering my RX. Hope this helps.
Old 01-26-02, 10:45 AM
MrSypher
MrSypher's Avatar
Question
Bro, do you still have the problem with rubbing with the smaller tires in thr back, and how is the ride and the feel while driving??
Old 01-26-02, 11:04 AM
leebro3
leebro3's Avatar
The ride is not as good mainly because I went from a 70 sidewall to a 40, but it is still not a problem. These tires clear the fender so rubbing is not a problem. Also, I get a better feel for the road because of the 245 upgrade from 225. Ideally, I would have liked to get 255/45-19 or 245/45-19 but at the time, I wanted to get more of an all season tire with good treadware (I dont know why I did this cause presently I have taken my wheels off for the winter!) but I ended up getting 245/40-19 Dunlop SP9000. Only problem I have with my tire selection is that the ugly fender gap is now a little bigger so I plan on adding lowering springs.
Old 01-26-02, 11:17 AM
MrSypher
MrSypher's Avatar
I gotcha... Thanks.
Old 01-26-02, 01:58 PM
Shonuff
Shonuff's Avatar
sypher: if you find a set that you like i might be able to get you a good deal on them.......i still have a few wholesale accounts set up from when i i owned a shop in south carolina.
Old 01-26-02, 02:31 PM
StrmRdr23
StrmRdr23's Avatar
i'm thinking of getting some 20x7.5" Equip by Works (jdm) but everybody on here looks like has 19" rims...is there some clearance/rubbing issues i'm missing? anybody got some suggestions on tire sizes? help!
Old 01-27-02, 07:35 PM
Swing913
Swing913's Avatar
Default I need help too
Hey guys, I just purchased a set of Racing Hart Z5000 19X7.5 and I have decided to go with tires 255/45/18. However, I haven't took the wheels to the shop yet, do I need spacers, or should I ask when is the time to use spacers??
Old 01-27-02, 07:39 PM
Swing913
Swing913's Avatar
Default SP9000
Hey I am also looking at the Dunlop SP9000, are they any good?
Old 01-28-02, 09:00 AM
MrSypher
MrSypher's Avatar
Sho, Thanks I will take some and look around I'll let you know what I see.. I do like thoses Antera 303. I think thats what they are... But thanks again...
Quick Reply: Considering to put 19" on RX300 -- any ideas? suggestions? thanks...
