Replacing window motor
Dear members,
I found that my passenger side power-window was acting strange. Both the driver master switch nor the passenger switch could have a very hard time to move the window up. Lubricating the window track had been tried but it didn't work.
Finally I replaced the window motor. Now the window can move up and down okay. BUT once it hits the top w/ automatic open, it just bounces back down to the middle and leaves it halfway open. Then I have to manually click up the switch until it closes all the way up.
Am I missing something here!? Some relay is also broken? Where? Or the window motor needs some special reset procedure? I have only tried holding the button down - wait 1 sec - and up to the top for 10 sec AFTER disconnecting the battery.
Anything else? Please help from all the experienced members.
Thank you so much!
Wynstan
https://www.clublexus.com/forums/ima...s/confused.gif
Thank you so much!
Wynstan
