Keyless entry no longer turning off lights
Old 09-11-07, 09:39 PM
toy4two
toy4two's Avatar
Default Keyless entry no longer turning off lights
Acting kinda screwy, doesn't always turn off the head lights (stalk set to AUTO), sometimes it doesn't beep, sometimes it beeps like 5 seconds after I've already walked away from the car. Anyone seen this?
Old 09-12-07, 09:11 PM
HarrierAWD
HarrierAWD's Avatar
A door may be ajar, or a sensor thinks that a door is.
Old 09-13-07, 06:38 AM
Mister P
Mister P's Avatar
I have the same problem on my GS300, and I believe it's the door sensor as well. The way I found out is that the light at the bottom of my driver's door does not turn on when I open it-- the car does not sense it is opened. You might check to see if there's this same problem with one of your doors. I have also noticed that it seems to happen during certain temperature changes-- FWIW
Old 09-27-07, 01:38 PM
toy4two
toy4two's Avatar
If it was the door sensor thinking it was open the car would make that long beeeeeeeeeeeeeeep to let you know when you try to lock it. It doesn't do that, and the interior light turns off.
I tried new batteries in the remote and another remote but that didn't help.
Old 09-27-07, 02:21 PM
Mister P
Mister P's Avatar
Hmm. Well, it sounds like the door sensor MAY be ruled out. If that door is open and no interior lights come on, then it still may be it. Otherwise, I'm not sure what the solution is.
RallyVT
10-31-17 10:16 AM
TechGreek
SC- 1st Gen (1992-2000)
03-13-11 12:17 PM
roblee8908
09-09-08 11:19 AM
Solo_D33A
06-22-08 07:30 PM
pjw7790
11-11-07 11:09 PM
Quick Reply: Keyless entry no longer turning off lights
