Go Back   Club Lexus Forums > Lexus Model Forums > RX Models > RX - First Generation
Thread Tools Display Modes
Old 06-16-07, 02:59 PM   #16
Lexmex
Trader Score: (0)
Lexmex's Avatar
Now get the other flathead ready. What you want to do is put the front of the flatheads underneath the tan piece as shown and push the tan piece up so that is can go up over the little plastic pice this holding it in place. This will be a little easier to see in the next few photos.
__________________
Homepage of my 1999 RX300 AWD
Lexmex is offline   Reply With Quote
Old 06-16-07, 03:00 PM   #17
Lexmex
Trader Score: (0)
Lexmex's Avatar
Here we have successfully gotten that small tan piece up and over the piece that was holding it in place. Not the hole in the tan piece.
__________________
Old 06-16-07, 03:01 PM   #18
Lexmex
Trader Score: (0)
Lexmex's Avatar
Now you may during this process have to give a small nudge first (before using the two flatheads together) in this area where another one of these small tan pieces with a hole is.
__________________
Old 06-16-07, 03:03 PM   #19
Lexmex
Trader Score: (0)
Lexmex's Avatar
Now you should see this. Not the small black knob just above the orange locking mechanism. This is where that little tan piece with hole in it hooked into. I will show a closer shot next.
__________________
Old 06-16-07, 03:04 PM   #20
Lexmex
Trader Score: (0)
Lexmex's Avatar
A close shot of that black piece.
__________________
Old 06-16-07, 03:05 PM   #21
Lexmex
Trader Score: (0)
Lexmex's Avatar
A shot of the black knob underneath.
__________________
Old 06-16-07, 03:08 PM   #22
Lexmex
Trader Score: (0)
Lexmex's Avatar
Next is the courtesy light. This is the most delicate piece to remove.
Carefully insert the small flathead at the top and push out a few millimeters and try to get at it by hand the first chance you get as the 4 little plastic hooks are very delicate.
IMPORTANT: (see second photo) I later found out after doing this a few times that you have the option not to do this and to wait to pull the door panel off and disconnect the electrical connector behind this area instead of doing this step.
__________________
Old 06-16-07, 03:09 PM   #23
Lexmex
Trader Score: (0)
Lexmex's Avatar
You should then see this.
__________________
Old 06-16-07, 03:10 PM   #24
Lexmex
Trader Score: (0)
Lexmex's Avatar
Insert the small flathead in the area shown and pry off.
__________________
Old 06-16-07, 03:11 PM   #25
Lexmex
Trader Score: (0)
Lexmex's Avatar
Next step is to disconnect the connection/wires behind this piece you just pried off.
__________________
Old 06-16-07, 03:12 PM   #26
Lexmex
Trader Score: (0)
Lexmex's Avatar
It should then look like this.
__________________
Old 06-16-07, 03:15 PM   #27
Lexmex
Trader Score: (0)
Lexmex's Avatar
Now if you forgot to lower the window completely, you should do it now. In order to do this you will need to reconnect the power window switch temporarily or the window will not lower.
The reason for lowering the window is to get easier access to the rails that raise and lower the window.
__________________
Old 06-16-07, 03:15 PM   #28
Lexmex
Trader Score: (0)
Lexmex's Avatar
Now, from the bottom use both hands to pull out the bottom of the panel.
__________________
Old 06-16-07, 03:16 PM   #29
Lexmex
Trader Score: (0)
Lexmex's Avatar
Then pull out along the sides.
__________________
Old 06-16-07, 03:17 PM   #30
Lexmex
Trader Score: (0)
Lexmex's Avatar
Then pull up from this point to lift the panel off.
__________________
Tags
04, 300, access, control, diy, door, fix, lexus, ls430, panel, put, removal, remove, rx, sc300
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Go
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
Copyright © 2000-2008 Internet Brands, Inc. All Rights Reserved
Privacy Policy | Disclaimer | Terms of Use | JOBS
