Go Back   Club Lexus Forums > Lexus Model Forums > RX Models > RX - First Generation
Thread Tools Display Modes
Prev Previous Post   Next Post Next
Old 06-03-06, 02:17 PM   #1
TunedRX300
Trader Score: (0)
Lightbulb Photo DIY 2: RX300 AWD Transmission Fluid, Pan, Filter Change
There are many helpful DIY instructions on transmission services on this forum, I have used them when I first did my ATF drain and fill. But no photo guide-through, especially for tranny pan and filter change. At 68355 miles, it is time to do a triple bypass on my 6 year old RX300, took some pictures along the way.
The whole procedure is not hard, just needs a lot of patience. If you don't have patience, tackle easier tasks such as ATF drain and fill first.
This thread is for tranny service procedure, please feel free to post if you find an error or find a better way to accomplish the goal. Please no tranny oil debate, that is not what this thread is for.
Last, not that it is likely, I take no responsibility if you (or the transmission) are injured or killed by my DIY instructions.
Step 1, Get tools and parts
Required tools: 1/4" drive wrachet or 3/8" with adaptor, 1/4" drive 3 inch extention, 10mm socket (6 point preferred), 10mm Allen wrench, flat head screw driver, plier (one in RX300's tool bag), funnel, shop towel, latex gloves, an oil pan, and lots of newspaper.
Optional tools: mechanic's creeper, RX300 service manual
Required parts: Transmission pan gasket, oil strainer and filter. Optional: O Ring
I ordered them from Park Place Lexus in Plano, part numbers are
ATF: 4 quarts for Transmission drain and fill, 1 additional quart for Transfer Case fluid and filter change, 2 more to Transmission Cooler and parital Torque Convertor fluid change. I used 7 quarts of Amsoil rather than OEM T-IV for better flash point protection. Other T-IV complying fluid is Mobil ATF 3309, pick one of your choice.
With the car running, check the ATF level before draining old fluid out. If the ATF level is low, make sure you compensate that amount when you refill.
TunedRX300 is offline   Reply With Quote
Tags
1999, amount, brake, change, fluid, flush, instruction, lexus, pad, pan, picture, replacement, rx300, sc400, splash, tools, total, transmission
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Go
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
Copyright © 2000-2008 Internet Brands, Inc. All Rights Reserved
Privacy Policy | Disclaimer | Terms of Use | JOBS
