Rear Differential & Transfer Case DIY
#182
Super Moderator
For tools, a 3/8ths or 10 mm hex wrench for the rear differential and a 15/16ths or 24mm bolt adapter on to a torque wrench will do the job.
#183
This string is so long and it might have been written but I just missed it... but the transmission takes 4 quarts drain/fill, but how much more does the front differential take for drain and fill on AWD models?
I should have read this before draining and filling my transmission... as now I wonder if I should drain and fill again with the front differential too, or now just drain the front diff. and fill the amount (from fill tube).
Thank you.
Thank you.
#184
I go through 4 1/4 quarts every time when I pop both plugs. But since they are connected together if you remove just the differential plug you will get a lot more than just that last 1/4 quart. I would say drive it for a week or so and do it again with both plugs. I definitely get some junk out of the differential. Unless you have done a few drain and fills recently it is probably a good idea to do a couple in a row anyway.
#185
Super Moderator
Keep in mind that my thread is only about the transfer case and rear differential that uses gear oil, not the transmission that uses ATF. I don't want to confuse people.
#186
Cleared
Then seeing your thread, I then thought "what the? that looks nothing like what I saw back there..." and then it hit me that there's a front diff. a transfer case, and a rear diff. (which I already knew where it was).
Anyway, I'll have to drain again at some point in next few weeks and just fill up again with 4.5 or whatever it takes, I'll take care to measure off and make sure it's level.
Thank you.
#187
hi morning,
Is this amsoil severe gear good for rear differential and transfer case??
http://www.amsoil.com/storefront/svg.aspx
i am planning to change with this gear oil, will it harm and damage??
cause i read this amsoil review some is positive some is negative, a bit doubtful here.
Besides, how about RP compare to this??
Thanks
Thanks
#188
Super Moderator
hi morning,
Thanks
Thanks
For a while in Mexico when I could not get Royal Purple, I actually used BMW's 75W140 gear oil and no issues. I later used Pennzoil Synthetic 75W90, but wasn't as happy with that as I was with the RP.
#189
That stuff is fine, too. I know some people who like the Severe Gear Oil over the the plain 75W90 they sell. If Amsoil had been more widely available in Mexico (it was a bear too import), I would have used the SVG given the conditions I had there. Being in flat Florida, I am continuing to use Royal Purple, but have been planning next time to try Redline's 75W85.
Thank you Sir..
Today i just changed the Severe Gear Oil, so far so good, havent really try for long journey yet.
Mayb 2 month later will change Toyota Type IV to Amsoil ATF as well, then see how is the tranny perform.
#190
I read threw most of this thread but not all, sorry lazy..... I just noticed a new leak on my 04 GX and it looks as if it is coming from the transfer case. Dealer says $1200 bucks to fix... WOW I dont think so. I hope not to highjack here but has anyone else had this leak and successfully fixed it?
#191
Super Moderator
You have to see where the leak is coming from. Is it on one of the side seals on the transfer case (round rubber-like rings) or on top like mine. You'd get a sulfur like smell if that is the gear oil.
I helped rectify my situation by using a 75W140 fluid for a bit as oppposed to the 75W90 when I was in Mexico to help kill a topside fluid leak, but it can to an extent help the side. However, changing to a heavier fluid is not a cure. Eventually, the the round seals on the sides of the transfer case need to be pulled and replaced and it's not cheap in terms of time.
#192
No problem on the hijack
#193
Great thread Lex. I plan on doing this later in the month after I get the new cat and resonator installed on mine. Quick question, has anyone found a replacement bolt for the filler plug? Just by looking at it now and thinking of future fluid changes, I want that nuisance gone as soon as possible. Dealing with it once seems like more than enough :P
#194
Super Moderator
If you are talking about the rear one, there is a clearance problem on the height of the head of the plug.
#195
Thanks for the awesome thread Lex. I followed your instructions and did this job almost 3 years ago. Now with almost 40k miles, it's almost time to do it again. How fun. But your instructions really made the job much easier, and we all thank you. BTW, I used Royal Purple. When I change it out in the near future, I'm curious how the fluid will look when it comes out.
I hate to get off subject, but am I correct in assuming it's probably a higher priority for me to replace the power steering fluid and brake fluid over the diff and transfer case gear oils. Given that it's been about 3 years and almost 40k miles, if you had to choose between doing 2 separate jobs, which would you give more priority to.
A. Power Steering fluid and Brake fluid replacement
B. Differential and Transfer Case fluid replacement
The reason I have to choose is because I only have very limited time to do it this Saturday. It will take a good portion of the day since I plan to also include a DIY oil change. After I complete one of the options above, I can knock out the other option in the next month or two. So which would you choose?
Also, when I do the brake fluid replacement (flush), you mentioned in one of your earlier post that you started using Pentosin Dot 4 brake fluid. Would this still be your choice over Valvoline Syn Dot 3&4? Thanks Lex for your guidance.
