Clock and Seat Memory lost overnight (updated)
99 RX300- Experiencing loss of memory in seats and radio as well as time on clock being off just from sitting overnight. Vehicle starts with no problem in morning. Looking for clues as to what this may be. This is the original battery so it is pretty old , is it possible that if voltage drops to a certain level as a power saving feature do systems start shutting thenselves off to save battery power?
Appriciate any input .
TR
TR
Originally posted by mikey00
Common problem on this and other forums. It's the battery.
Follow up to memory loss problem
A couple post earlier I posted regarding the loss of seat, radio and clock memory. I appreciate the responses which support my guess which is that the battery is going. This morning the lcd display was blank. It was lit, blue, however nothing would come up on it. My wife drove a little, stopped the car and then when she came back and restarted it all was back up. Could this be result of battery problem as well? I am guessing that after she drove it the battery charged enough to reboot the screen upon restart.
What I don't understand about all this is how can the battery start the car just fine but can't keep low voltage systems up overnight?
What is a good battery replacement and don't say Autozone, their stuff stinks. What should the amp reading be on the battery so I can tell if my current one is actually going.
Thx
Thx
I suspect one cell of your battery is expiring. This would result in a low voltage condition and several of the electronic systems require the correct voltage. You can test for this by using a voltmeter if you have one. Check that the battery voltage is at 12.6 vdc in the morning after the car has been sitting overnight. After starting the car the voltage should be between 14-15 vdc. Another test and a better one is a load test. AutoZone or other similar auto stores will do a load test on your battery for free. This simulates the operation of the battery under a moderate load. Bad Cells show up very quickly in this test.
I've not done a lot of research on battery quality recently but my experience with Interstate batteries has been excellent. You may want to google "auto battery ratings" and see what comes up.
Re: Follow up to memory loss problem
Thx
Thx
Good luck!
For $38 go to Costco and get the battery and get the problem over with. It's cheaper and less hassle than troubleshooting the problem and you can be pretty sure it will solve the problem. A 99 with the original battery is about due anyway.
MIke
MIke
I don't know anything about the GX. I was basing my comment on info found on this forum (which I thought was an RX forum) and other RX forums I visit. Many RX's (especially 99's) have had this problem corrected with a new battery. You may want to try your question over on the GX forum.
crwiseman
GS F (2016-present)
14
02-03-23 06:34 PM
DaveInMesa
RX - 1st Gen (1999-2003)
05-07-16 08:48 AM
