Rear door panel, removal.
Old 07-19-04, 04:19 PM
LophatRX
LophatRX's Avatar
Default Rear door panel, removal.
Hey,
I was trying to pull apart the rear door panels to check the room of the factory speaker, because I want to replace them with some Infinity kappa 3 ways into those location. It seems like they may not because of the tweeters sticking out of the Infinitys. So I want to take it apart to see how to make it fit cause I see that there is a mounting, hole that the factory speaker fits in.
When I tried to pull some of it apart I couldn't get the plastic around the door handle, off and I had the same problem with my wife's old Camry and broke it, so I definately don't want to do that again. I also coudln't figure out if there was another screw in the door handle, near the window button. Anyways if any of you have tackled this job and have any hints, tips, tricks or uniquie tools I should use to pull them off I would appreciate they help.
Thanx in advance.
stemirra
08-25-19 06:43 PM
EricinSA
04-16-12 10:51 AM
SISMO817
GS - 1st Gen (1993-1997)
04-16-07 12:03 PM
tytgs300
03-06-05 02:29 AM
tmh91
05-11-01 01:45 PM
Quick Reply: Rear door panel, removal.
