RX300 Engine Vibration
Old 02-08-04, 12:46 PM
kjyfkjy
kjyfkjy's Avatar
Default Rough Idle
My 99 had a full tune-up at the dealers about 6000 miles ago now it's running rough at idle (in gear). Not drasticaly but you couldn't even feel it running before, it ran so smooooth. Any ideas what could have happened before I take it down to the $Dealer$ ?
Old 02-08-04, 04:15 PM
parula
parula's Avatar
I am starting to have this issue too and more with warning lights, see this thread:
https://www.clublexus.com/forums/sho...hreadid=109739
Old 03-14-04, 12:41 PM
kjyfkjy
kjyfkjy's Avatar
Default engine idle problem
Has anyone figured out and or fixed the engine vibration problem at idle under a load?
Old 03-16-04, 08:24 AM
Fern
Fern's Avatar
You ask about engine idle problem and in same sentence mention "under load"...
Please explain how car can be at idle and under load???????
Thats like coasting uphill..>?
//Fern
Old 03-29-04, 08:24 PM
kjyfkjy
kjyfkjy's Avatar
Quite easily it can be in gear with your foot on the brake
Old 03-31-04, 10:05 PM
seravios
seravios's Avatar
I noticed the same problem as well, when i stopped at a junction,while still engaged on 1st gear (auto),the engine vibrate sound can be felt,more than when the transmission is in neutral position.
Is there any adjustment to be made to reduce it?
Kelvin
2000 Rx300
Old 04-01-04, 01:43 PM
kjyfkjy
kjyfkjy's Avatar
Default Someone must have an answer...Are there any mechanics on this board?
Please explain how car can be at idle and under load???????........FERNS GOOFY RESPONSE
Kelvin
2000 Rx300
Old 04-01-04, 04:51 PM
seravios
seravios's Avatar
Well, i took the trouble to speak to my mechanic. He said to check on 2 things. One, he want to know if your idle speed (in neutral) is too high. Second, get someone to check out your engine rubber mounting.
He will look into my car today. But mine only run 25000km. fairly new.
Old 04-01-04, 08:24 PM
Fern
Fern's Avatar
Default Re: Someone must have an answer...Are there any mechanics on this board?
Kelvin
2000 Rx300
Kelvin,
my response was not meant to sound GOOFY. I was just trying to explain that your question did not seam clear.
When you said "vibration at idle under load", did you mean, ie: car in drive and foot on brake?
If that is the case, my car also has a slight vibration when engine is cold and foot on brake while in drive and stopped at light. More noticeable if I have used lower octane fuel.
Old 04-01-04, 09:41 PM
seravios
seravios's Avatar
there is some misunderstanding here,I am Kelvin,and i didnt make that statement. That guy above must have copy and paste ... thus incld my name there.
I agree,what u said is correct,how can it be idle yet under load.
Kelvin
2000 RX300
Old 04-02-04, 06:07 AM
Lexmexico
Lexmexico's Avatar
I noticed this too just before I tightened the nuts holding the rubber mount on the right side of my car. No more vibration.
Old 04-02-04, 06:15 AM
kjyfkjy
kjyfkjy's Avatar
One more time...If the engine is running (even at idle) and you have it in gear with your foot on the brake..it is under a load. The car wants to move forward and you are not allowing it...thus it is under a load, granted not a tremendous one but a load all the same.
Old 04-02-04, 07:07 AM
mikey00
mikey00's Avatar
Turing on the A/C compressor will also add some additional load at idle.
Old 04-02-04, 05:53 PM
seravios
seravios's Avatar
Lexmexico,
What is the recommended idle rpm for RX ?
Kelvin
MattLS400
190
03-18-21 03:28 PM
reloj
06-22-08 07:21 PM
dashan
01-22-08 07:24 PM
truevietlu
06-10-07 07:40 AM
32kcolors
06-26-06 01:16 PM
Quick Reply: RX300 Engine Vibration
