My RX300 w 18" Imola rims
Old 02-22-04, 10:01 AM
jmezo
jmezo's Avatar
Default My RX300 w 18" Imola rims
Just got my new rims off of ebay. Silver Imola 18" with Mitch 235-55-R18 tires. I needed 1/4 inch spacers on the rear wheels and extended lug nuts (not studs) that go deeper into the rim hole. The RX lug nuts have washers and were not compatible anyway. The Imola rims are 18x8 with 40mm offset. The tires just rubbed without a spacer.
Old 02-22-04, 10:02 AM
jmezo
jmezo's Avatar
Default pics
pics
Old 02-22-04, 10:06 AM
jmezo
jmezo's Avatar
Default one more
pic
Old 02-22-04, 12:22 PM
HarrierRX300
HarrierRX300's Avatar
Looks great. Can you take a close up picture of the lug nuts? I want to see how far the extended lug nuts stick out and how much farther the rear rims stick out. I just got 18's too and used the stock washer/lug nuts without spacers in the rear:
https://www.clublexus.com/forums/sho...hreadid=110802
Old 02-22-04, 09:31 PM
Technics
Technics's Avatar
You'll be looking sharp all-season!
Old 02-23-04, 12:10 AM
JohnsRX
JohnsRX's Avatar
Default Re: My RX300 w 18" Imola rims
somehow ur 18s look bigger than my 19s, is it because of the white foam u got sprayed all over the ground????!!!!!]
Originally posted by jmezo
Just got my new rims off of ebay. Silver Imola 18" with Mitch 235-55-R18 tires. ....
Old 02-23-04, 08:09 AM
Fern
Fern's Avatar
Default Great look!
WOW!
Can't get over how nice the RX looks on 18's very classy -
Looks like car was designed to ride on 18's.
how's the speedometer given the fact that the 235/55-18's are smaller overall diameter?
My calculations show the following wheel & tire overall height in (mm)
225/70-16 (721.4)- stock setup
235/70-16 (735.4)- suggested by some members to be an alternative to stock tire size
235/55-18 (715.7)- your setup
235/60-18 (739.2)
Cheers,
Fern
Old 02-23-04, 10:24 AM
jmezo
jmezo's Avatar
Default Re: Re: My RX300 w 18" Imola rims
Your right. I measured my rims and they are 19.5" dia. But they are 18" rims and 18" tires.
Old 02-24-04, 11:23 AM
jmezo
jmezo's Avatar
Default Re: Great look!
Originally posted by Fern
WOW!
235/60-18 (739.2)
Cheers,
Fern
A good site for tire calculations is: http://www.miata.net/garage/tirecalc.html
The 235 tires are .8% to fast. At 60 MPH on the spedo the actual speed is 59.5 MPH
A good rule is to keep the tires within 3% of the designed tire size.
Old 02-28-04, 03:50 PM
jmezo
jmezo's Avatar
Heres a pic of the lug nut.
Old 03-01-04, 08:32 AM
HarrierRX300
Thanks Jmezo,
What foot pound do you torque it to?
Fjaw
07-22-12 01:21 PM
branddz
03-25-10 08:54 AM
StunnaSC
09-01-06 03:05 PM
VEGASRX330
Wheels, Tires & Brakes Forum
06-03-04 09:20 AM
SprtDesign
09-12-02 12:39 PM
Quick Reply: My RX300 w 18" Imola rims
