Winter Tires and Rims
Old 09-08-16, 11:50 AM
destro888
destro888's Avatar
Default Winter Tires and Rims
Good day,
What are the recommendations for winter tires including brand and tire sizes? Also, what are good winter rims for our vehicles?
I like purchasing based on value but don't mind spending more if it makes a bigger difference.
Thanks.
Old 09-08-16, 07:01 PM
Comfort
Comfort's Avatar
The Michelin X Ice is a great winter studless snow tire. Might check Tire Rack for a tire and wheel package. When I bought mine they mounted and balanced free and shipping was about $60. At the time it was $150 cheaper than Costco. The tires cheaper than Costco but with Costco you get free rotations, nitrogen and they balance tires at each rotation. About a toss up if you are going to run them 4-5 years.
I have always ran Blizzacks in the past, but now prefer the Michelins....better wear and great on ice and the slickest roads like when packed snow floor gets warm with a wet film. Last winter heavy freezing fog made for black ice on a stretch of freeway. There were vehicles upside down and in the median and mine didn't slip at all.
Consumer Reports does extensive testing so it wouldn't hurt to see their current reviews.
pfloyd (08-12-20)
Old 09-12-16, 11:57 AM
FastFord
FastFord's Avatar
I am going to use my old winter rims from my 3RX. I installed Nokian Hakkapeliitta R2 SUV in a 235 65 18. This size is within 0.5% of the stock 20" tires. I had Nokian's before and found them to be very good in winter conditions. They also wear very well.
Old 10-24-16, 10:13 AM
breeznn
breeznn's Avatar
Default reusing old RX rims for snows
To those adding aftermarket wheels or using wheels from previous RX's what are you doing about TPMS?
I have a set of 18" wheels with TPMS monitors from our past 2008 RX400 that I wanted to put snows on for my wife's 2016 RX350. The 2016 TPMS system indicates individual tire pressure at each wheel but the old system just notified if any one of the tires was low. The dealer has not been able to verify if the old TPMS equipped wheels will work on the new RX350.
Old 10-25-16, 06:57 AM
Flooreye
Flooreye's Avatar
Default Size of winter wheels
Hi all, I just decided to buy a set of winter tires and wheels for my 2016 RX350 F Sport. Just wondering if that is possible to use 18" rims on it, cause it originally come with 20" rims.
PacNW (01-01-22)
Old 10-25-16, 08:43 AM
Darith
Darith's Avatar
Thumbs up
Correct, you can use 18" rims on it as long as you have the 235/65/R18 size to to match the closest diameter of your original tires (which is in a safe 0.50% diameter variance under the recommended 3%) compared to your 235/55/R20.
Old 10-25-16, 09:42 AM
Flooreye
Flooreye's Avatar
Thank you Darith, that is helpful.
Old 10-27-16, 07:49 AM
creoledude
creoledude's Avatar
What is the best size winter tires to get for my 2016 RX350 Fsport, Current size is 235/55R20? 18", 19" or 20" (if 19" what measurement do i need?
and what rims beside OEM ones?
thanks
Old 10-27-16, 02:14 PM
FastFord
FastFord's Avatar
That depends on how much you want to spend, and how you want it to look. I just used the stock RX350 rims. I had them as a winter tire package from the 3RX. I had to change the tires to a 65r from a 60r to keep it in spec.
18 inch rims are probably cheaper and easier to get, plus the tires are probably easier to get as well, and more selection. The sidewall is taller and that should be good for the winter.
19 and 20 " rims are going to be more expensive and not as many options for tires.
Old 10-28-16, 06:30 AM
creoledude
creoledude's Avatar
Thanks for the reply, so for a 235/55R20, an equivalent 18" will be 235/65R18, is that right??
Old 10-28-16, 10:35 AM
FastFord
FastFord's Avatar
That's correct 235/65/18 is almost the same as your original 235/55/20, taller sidewall but everything important the same.
Check out this web-site. It gives you everything you need to know about fitment
http://www.wheel-size.com/calc/?whee...cl=50mm&sr=0mm
This is my offset and rim width that I have. If you get a different rim width and/or offset, don't forget to change the values in the chart.
Old 10-28-16, 04:57 PM
toyotaman7
toyotaman7's Avatar
Lexus Canada has a winter tire package with 18" lexus rims, sensors and Michelin tires.
I'm getting mine installed next week.
RXBurbmom (11-15-17)
Old 10-30-16, 05:46 AM
FastFord
FastFord's Avatar
Ask them if the package includes center caps. My package didn't come with them. You can flip the stock ones but I didn't want to chance breaking them. The dealer sold me caps for the winter tire package at cost. They are pricey little buggers.
Old 10-30-16, 09:56 AM
toyotaman7
toyotaman7's Avatar
Parts manager said they come with the wheels. Are there the wheels you got? Lexus Canada and Europe accessory wheels.
Part number PW457-0E000
Old 10-30-16, 12:08 PM
FastFord
FastFord's Avatar
Ohh those rims are nice!! These ones are mine., kind of look dated compared to yours. Hakkapeliitta R2 Suv
Attached Thumbnails Winter Tires and Rims-p1010004.jpg   Winter Tires and Rims-p1010002.jpg
Quick Reply: Winter Tires and Rims
