Touch Free Rear Door Issues
Old 01-01-16, 09:54 PM
kenforum
kenforum's Avatar
Originally Posted by Samour
I think it needs the car to be locked to be operable.
I found out that the car does not need to be locked in order to use the touch free rear door. For example I could use it even when the side doors are open.
Old 01-02-16, 06:49 AM
RXOwner
RXOwner's Avatar
I stand corrected and you are correct. It will open even if unlocked.
Old 01-02-16, 10:40 AM
aznkorboi
aznkorboi's Avatar
the manual says you can wave or touch the upper part of the lexus emblem.
It also says that if you press the close gate button twice, it will close the trunk AND lock the doors! haha
Old 01-02-16, 11:16 AM
RXOwner
RXOwner's Avatar
I found out early that waving does not work near as good as holding something in front of it.
I figured out the two push thing by the 2X and the lock graphic by the button. It works quite well.
Old 01-02-16, 06:35 PM
coolsaber
coolsaber's Avatar
During the test drive, car was running, unlocked, Driver door open and it worked.
Old 01-14-16, 10:44 PM
Haya808
Haya808's Avatar
First time I actually had a real world situation needing to use the touch less feature. Bought two jugs of Starbucks coffee for a work meeting, with cups and extra all attached to the boxes. So both hands were completely full. Held up my elbow to a locked RX and in 3 seconds the door opened exactly as it should! I was so happy it worked...especially when I really needed it too!
Old 01-14-16, 10:54 PM
kenforum
kenforum's Avatar
All of these work very well for me too
Old 01-20-16, 06:21 PM
barx
barx's Avatar
Mine seems to work inconsistently, but it's usually when my wife is around and in the car, possibly with her set of keys in her purse too. There's definitely some edge cases to work out, but I feel that if you can push the button underneath to open it, you should be able to wave the emblem to open it.
Funny story though, the touch free rear door seemed to work really well when I was washing / waxing my car and had the keys in my pocket. Who would've thought that would be an edge case.
Old 01-21-16, 09:43 AM
MediumRare
MediumRare's Avatar
I believe you are correct.
That is unbelievable... Thinking twice about getting it. Kick open in our Beamer works so great. Hands free, instant response, works whether locked or unlocked.
Old 01-21-16, 09:45 AM
RXOwner
RXOwner's Avatar
Try to remain calm.
Old 05-17-16, 04:16 PM
Ricjames31
Ricjames31's Avatar
Default sensitivity:
Originally Posted by SoKali-RX
There's a sensitivity setting in the Vehicle Customization section where you can dial up the sensitivity. Mine is at normal and opens every time within 2 seconds, hand or elbow, regardless of body position. Try turning up the sensitivity to see if that helps.
sensitivity cannot be changed by customer only by dealer by a service tech
Old 05-18-16, 08:06 AM
gorcorps
gorcorps's Avatar
Seriously? Why? What else is locked out from me adjusting it myself?
Old 05-18-16, 08:11 AM
coolsaber
coolsaber's Avatar
Theres a list of things posted here on another thread
Old 05-18-16, 08:13 AM
Ricjames31
Ricjames31's Avatar
just about every thing to be honest. the only you can do is adjust the height settings from lvl 1-5 and that's it.
Old 05-18-16, 08:51 AM
sirtiger
sirtiger's Avatar
It works for me. My personal opinion now is that it is a waste of an option.
Quick Reply: Touch Free Rear Door Issues
