3rd gen RX to which gen highlander?
Old 01-21-17, 10:32 AM
Marqevans
Marqevans's Avatar
Originally Posted by Marqevans
i think it's more noticeable on lane changes or merging than on start ups. I don't drive the Highlander as often and it just might be my perception. There seems to be a slight hesitation when punching the RX. It could be the slightest difference in transmission manufacturing.
Keep in mind the 2015 RX is an old generation of the RX, where as the 2015 Highlander is an almost brand new generation of the Highlander.
Old 10-12-17, 02:31 PM
eross1981
eross1981's Avatar
I know it's a 9 month old thread, but it's a slow day today.
So anyway... generally speaking:
No Highlander in US = '99-'00 RX300
'01-'03 Highlander = '01-'03 RX300
'04-'07 Highlander = '04-'09 RX330/350
'08-'13 Highlander = '10-'15 RX350
'14-up Highlander = '16-up RX350
From what I've noticed, it looks like the Lexus design language translates across 2 generations. So, the '99-'03 RX300 is similar to the '04-'09 RX330/350. Whereas the L-Finesse design in the '10-'15 RX350 is similar to the '16-up RX350.
Old 03-22-18, 12:59 PM
Marqevans
Marqevans's Avatar
One other thing the standard premium stereo in the RX absolutely blows away the JBL stereo in the Highlander. Beyond that anyone who says there is no comparison between the RX and the Highlander should really test drive a Highlander Limited. Another thing, if your leasing, I think you will find the monthly payments on the Lexus to be about the same, due to incentives, even though the MSRP is easily 10,000 higher on the Lexus.
Old 10-05-21, 06:40 PM
Flukes
Flukes's Avatar
Default Lifting?
So if I’m understanding this thread correctly I have individual shocks in the rear suspension of my 2010 RX 350? I’m trying to figure out how to lift my RX but the spacer plugs on offer are a bit short for what I want to do. If I wanted to do a 2-3 inch lift could I just put longer struts in the front and longer shocks and springs in the back?
Old 10-06-21, 01:14 PM
Clutchless
Clutchless's Avatar
Received 1,098 Likes on 937 Posts
I thought there were no lift kits for the RX350. It is not that type of vehicle. Note that you cannot just throw random longer struts, shocks and springs on it without regard to vehicle weight, spring rates etc as they would probably make your vehicle undrivable with terrible handling. They have to be designed for the vehicle.
Then I found this https://risingtuning.com/lift-kits/product-898
and this https://northwoodsperformance.com/pr...350-2010-2015/
Although neither lifts it as much as you want, which I think is too much for the wheelbase and track, and will result in poor handling and instability. You don't want to be like an old Jeep and rollover on an exit ramp.
Which sort of rendered moot my original opinion below:
There are some for the 2014-2019 Highlander but I do not know if they would work with the RX although they have very similar suspensions. You would have to ask the manufacturers such as https://www.readylift.com/2-0-sst-li...hlander-1.html
See this thread regarding the 3rd gen Highlander which has about the same suspension front and rear although spring rates and shock valving and maybe length are probably a bit different as it weighs more.
Farther into the linked thread are some other ways to attempt to raise your vehicle, although I would not recommend them. Go buy a 4Runner if you want to lift it.
​​​​​​https://www.toyotanation.com/threads.../#post-9931474
Old 06-03-23, 03:44 AM
Abrar
Abrar's Avatar
Originally Posted by Clutchless
The front struts are interchangeable. However you need to compare part numbers if getting OEM struts. They are different for Japan built and Canada built RXs. I do not know if the Highlander has different part numbers. If you want a floatier ride try the KYB struts as others have installed the KYB shocks in the rear and said they gave a smoother ride. Look at their application guide as they list the same part numbers for both vehicles for the front struts. KYB struts and shocks have a better durability/quality reputation than the OEM Tokico brand struts/shocks.
I
http://www.kyb.com/catalog/
great , would you be familiar with differences between the Japanese and the Canadian versions ? Is it build quality or duty ?
Old 06-03-23, 05:13 AM
Clutchless
Clutchless's Avatar
I have no idea. Basically I was talking about making sure you get the correct part that will fit your vehicle.
Most aftermarket parts companies do not differentiate between the Canada built and Japan built versions of the RX.
Just get the ones listed for your year and model vehicle.
Old 08-24-23, 02:55 AM
vhcaceido
1st Gear
vhcaceido's Avatar
I wait new ver of MDX.
b2884987
09-17-18 06:14 PM
Kulharin
RX - 4th Gen (2016-2022)
06-08-18 12:27 PM
BertL
RX - 3rd Gen (2010-2015)
04-01-15 11:19 AM
tadeusz
03-30-12 08:14 AM
Quick Reply: 3rd gen RX to which gen highlander?
