Multiple Malfunctions All At Once
Hello All,
Our 2011 RX350 has been a champ, no real issue until yesterday
I started the Vehicle and the Display Showed Brake Malfunction, Check ABS, Check AWD, Check AFS
Indicator Lamps lit up are ABS, Brake, AFS Off
Quite strange, the must be a common failure, any ideas?
The closes Lexus Shop is over an hour away
Just a thought... perhaps you could post this in the Maintenance forum as well. Someone there may have run across this before. From what you describe, I suspect it is not specific to the RX family of vehicles as it sounds more systemic in nature (ie. some electronic module malfunction).
Do you have a Kragen, Autozone, or even a Garage near
Hello All,
You should pull codes 1st.
Is it possible that you filled up recently without the fuel filler cap being sealed shut or is the cap cracked?`? Dumb I know but.... Good Luck.
One time my 1st Gen lit up like a Christmas tree after a cheap oil change.
Seems they wanted to see if they could sell me an air filter and knocked a hose loose on the back of the air filter cover while checking.
I was not impressed with their marketing skills.
bklynchris
11-29-15 04:13 PM
