2011 RX350 Audio Amplifier Location?
Old 07-26-16, 03:21 AM
rrichard7
rrichard7's Avatar
Default 2011 RX350 Audio Amplifier Location?
The sound on our 2011 RX350 quit. No NAV, Radio, etc. I suspect the amplifier. Fuses all check out. It goes to the dealer tomorrow. We purchased the RX in 2014 as CPO. Does anyone know the location of the amplifier (in the hatch)? I was going to check connections before the appointment. Fortunately, my wife purchased an extended warranty (something I would not have done given Toyota's reputation for quality). We'll see what they come up with.
Thanks,
Ray
Old 07-26-16, 05:35 AM
rrichard7
rrichard7's Avatar
Found the amplifier seat side of the spare. Nothing hanging. Leave it to the dealer since there is a warranty.
Old 07-26-16, 07:40 AM
TeeDog
TeeDog's Avatar
Good luck, hopefully it's something simple
T
Old 07-28-16, 03:08 PM
ColAngus
ColAngus's Avatar
Hopefully it's not this:
https://www.clublexus.com/forums/rx-3rd-gen-2010-2015/796670-navigation-quit-no-heat-no-radio-11-rx350.html
Although... at least you still have warranty
Old 08-01-16, 03:07 AM
rrichard7
rrichard7's Avatar
Amplifier is bad. It goes back today for the swap. Hopefully nothing else surfaces.
Old 08-01-16, 02:15 PM
rrichard7
rrichard7's Avatar
Replaced under warranty. Receipt $768.93.
Old 08-27-16, 12:22 PM
stingrey
stingrey's Avatar
rrichard7, what do you mean by "seat side" of the spare? Behind the rear seat and in front of the spare? All sound on my 2010 RX350 just stopped yesterday. Same symptoms as I've read in the Forum, scratchy noise from front speaker at start-up, etc. Thanks
Old 08-29-16, 10:30 AM
rrichard7
rrichard7's Avatar
Sorry, not very clear. It is under the floor in the hatch. Remove the floor/cover to expose the spare. The amplifier is in between the spare and the back seat on the passenger side. Large metal box with cables. We purchased a bumper to bumper warranty, amplifier was covered. Our receipt showed $768.93. Our sound got poor and then none.
I hope this helps, Good Luck.
Old 09-14-16, 08:37 AM
stingrey
stingrey's Avatar
Thanks rrichard7. Replaced the amp and it all returned to normal. Since I work at an engineering company, we decided to take apart the old amp and attempted to troubleshoot it. We found no easily visible fault (burnt out area on the boards, etc.). It is a component failure and without the schematics it becomes impossible unless you want to devote endless hours.
Being new to the forum I don't know where to look for schematics... any ideas where to search. Thanks
Old 09-19-16, 03:30 AM
rrichard7
rrichard7's Avatar
Sorry, I don't.
Old 07-19-17, 04:21 AM
Allen346
Allen346's Avatar
Angry 2011 Rx350 Amplifier Repair
I recently lost all sound in my 2011 rx350, no radio, CD player or nav sound. The dealer diagnosed as amp issue. Unfortunately pioneer is out of stock for three weeks or more. Based on info from this forum I have located and removed the Amp. But I need some recommendations from members who have used a Auto Electronic shop to repair.
Old 07-19-17, 05:29 AM
TeeDog
TeeDog's Avatar
You can call these guys in Florida, they repair factory radios and amps. I personally have not used them, I was surfing the web and ran across them.
http://www.carstereohelp.com/lexus.htm
T
Old 07-19-17, 06:03 AM
salimshah
salimshah's Avatar
When it comes to audio/nav equipment, Lexus specs and purchases from Pioneer/Nak/MarkL etc. If you have the Lexus service manuals (or access to them) they will stop at the connector. For repair (with or without warranty), Lexus dealers simply swap out the units and their techs do no attempt to get into the units. As an owner, you can search for repair facility and usually the flat repair cost I have seen for first gen end up close to what you can purchase from salvage yards. LKQ is a good source I have used in the past.
Salim
Old 07-25-17, 11:11 AM
PDF84
PDF84's Avatar
Salim
This is all good info Salim. I had the factory amp go out in my 2013 GS and It rendered my infotainment system useless until the dealer warrantied out the amp and swapped it out.
tna
IS F (2008-2014)
15
11-16-15 12:30 PM
MILERrx
RX - 3rd Gen (2010-2015)
12-14-14 08:59 PM
jud149
06-02-13 03:18 PM
PghLex
12-15-11 09:17 AM
wr332
09-15-10 09:42 AM
Quick Reply: 2011 RX350 Audio Amplifier Location?
