Blue Tooth Audio paring issue
Old 06-28-16, 12:35 AM
cheapshot
cheapshot's Avatar
Default Blue Tooth Audio paring issue
Hey, guys so far i haven't had a single issue with my rx350..but recently got a new phone (S7) it paired with bluetooth for the calling but it won't let me pair it with audio to play music from my phone...right now i'm just using my iphone and a USB to play music...but i'd prefer to use my S7...just using a USB and my s7 won't work for some reason...
does anyone know what i can do here? it doesn't NEED to be using Bluetooth to play i don't mind if it works one way or another, i just want to be able to use my S7 as the primary music source instead of my Iphone.
i have a 2012 RX 350
Old 06-30-16, 07:57 AM
offroad200
offroad200's Avatar
Andriods and USB don't work like iPhones do. They won't play music over USB. On your RX, the pairing of the audio player is separate from the pairing of the phone portion. Do you have navigation? If so, it's something like Setup>Audio>Bluetooth Audio Settings>Register. If Register is grayed out, you may have to Remove a player. It only holds 2.
Old 06-30-16, 11:55 AM
cheapshot
cheapshot's Avatar
That worked! thanks!!!
for some reason i had to have it connected with the USB on first attempt to connect via the bluetooth audio setup...it wouldn't connect otherwise.
really appreciate the help!
ejm3
RX - 3rd Gen (2010-2015)
14
09-24-21 04:58 PM
nfordhk
05-30-16 07:52 AM
HappyWife
RX - 4th Gen (2016-2022)
05-27-16 11:20 AM
LEX Fairy
11-05-11 03:17 PM
HSinNoVa
HS 250h Model (2010-2012)
03-03-10 12:23 PM
Quick Reply: Blue Tooth Audio paring issue
