Strunk strut get rusty
Hi
I just bought a Lexus R350 2015. I didn't see the rusty from the trunk strut when I bought it. My question is the car is only 1 year old and the trunk strut rusty? will it cover by warranty if I complain to Lexus Canada? Will the rust spread around other part of the car?
Thank you.
Tri.
Thank you.
Tri.
Rust does not spread, it simply occurs....moisture on bare, ferrous metals = rust. If there is no moisture, or if the metal has a good protective coating (paint, etc), rust will not occur, or will at least be very unlikely.
When you say "strut", are you talking about the little piston/shock absorber that holds up the hatch? If so, that is a replaceable part, and should be covered by warranty.
Ask your service advisor about the rust. I am fairly certain he will tell you there is nothing to worry about.
