How do I know if my RX 350 has tow package? (merged threads)
#46
"tow package" consist of larger oil cooler and higher capacity radiator and alternator. from what I know, Lexus decided to make "tow package" for RX standard starting 2013 so there will no longer be an option list. my guess is you already have a tow package if you have the "plug-in" for your oem wires.
first thing I did for 2010 RX in 2009 was to add a CURT hitch [$125] and $40 oem cable. it's fairly easy to install except for middle part you will have to cut-out. there are few step-by-step instructions on this site. 1-2 hours for anyone who know how to use a wrench and a box cutter.
#47
#48
My 2015 does not have it, I check the left font fender well and there is no cooler installed, simple vents you can see through.
It was a purchasable option when order. I checked my VIN also.
I am concerned simply adding the aftermarket tow bar without the tow package, then having warranty issues that they could point fingers at and may not cover.
T
Thanks
Sorry to hijack someone else thread here.
T
Thanks
#49
Thanks for recommending Curt Hitch. The Curt installation video seems pretty straightforward so I will tackle this install myself.
I just ordered the Curt Hitch 13143 on Amazon for $120 with $20 off coupon. I'm just using this to mount the Allen 4-bike hitch mount rack (ordered today as well).
#50
I just ordered the Curt Hitch 13143 on Amazon for $120 with $20 off coupon. I'm just using this to mount the Allen 4-bike hitch mount rack (ordered today as well...
You will be pleased.
#52
I'm going to be towing my motorcycle. If it was just a bike carrier then that would be the way to go.
Traveling to Vegas and Arizona I like knowing I have the cooler added for the heat.
Thanks
T
Thanks
T
#53
I just checked and my wife's 2015 RX 350 has the same cooler. So I guess our RX has transmission cooler also which is a big plus because I just installed the hitch.
Ordered the hitch from Amazon yesterday and it's delivered today. Got a love Amazon Prime!
It's pretty straightforward install. I think the hardest part was removing the plastic undershroud.
#56
#57
Yes, very easy. I used a dremel.
#58
#59
I installed a hitch on my X3 and I had to cut some plastic on it. It always irked me a bit looking at it as the plastic was thick and not easy to cut and it didn't look great. That being said, when I sold it the buyer didn't complain.
