RX350 Battery Details
I replaced my Lexus battery a few months ago. I was looking under the hood, maybe checking fluids (can't remember now) and I saw one of my battery terminals was COVERED in corrosion. I've never seen one that bad. So while trying to remove the cable, we pulled the post out of the battery -- that's how corroded it was (even after doing the baking soda/water thing). At that point there was nothing to do except buy a new battery. The odd thing, to me, is that I've had the Lexus almost two years and it has never not started or even hesitated to start. Just lucky, I guess.
That got my OCD issue all fired up.
I am about to fly to your area and clean that crap myself.
At 12.11v your battery is only at a 50% State of Charge.
You either have a weak battery or you have something discharging your battery overnight due to a high parasitic drain.
Once again, anything over 50 ma or so is suspect.
Here's a good YouTube video with explanation and troubleshooting info
How To Perform a Parasitic Draw Test - EricTheCarGuy - YouTube
Good luck.
Good luck.
I believe your 2010 RX350 takes a Group 24F battery, which is one of the most common car batteries on the market.
If your battery is more than 3 years old just replace it. You're location shows Washington State. Batteries do well in the PNW. Here in Florida heat kills batteries and rarely do they go more than 3 years before failing.
If you're a member of Costco check out their prices for a group 24F.
BatmobileX
RX - 3rd Gen (2010-2015)
17
11-29-15 11:07 PM
gurjot
07-01-08 04:49 PM
kqt2ktval
12-12-06 07:42 AM
