2010 RX350 P0138 and C1241 codes
My wife suddenly had error messages today, Check AWD System, check engine, traction. Carista reports P0138 O2 sensor high circuit voltage bank 1 sensor 2and also C1241 ABS low battery positive voltage. I get the O2 sensor or wires could be bad, but the C1241 could be expensive ECU. Think both could happen at same time or just a thrown code? Reset turned warnings off but Carista reports permanent for P0138.
I believe someone here posted similar thing a while ago and the issue was with the battery ( for that person) check your battery life, see maybe a new battery can do the trick otherwise hit the dealer
Believing in the cheapest fix first, I would make sure the gas cap is tightened all the way. Tighten it, fill up the tank, tighten the cap again. Wait a few weeks (or go to an auto parts stood to have them reset it
Oh it's just the dreaded 68666 devilish mileage!
