3RX Brake Replacement
Old 10-26-15, 01:29 PM
Yurka
Yurka's Avatar
Default 3RX Brake Replacement
My brakes are running low,I need to get them replaced, is it worth getting them done at the Lexus dealership or can I order good breaks online and just get them installed on my own.
TIA
Old 10-26-15, 01:34 PM
JDR76
JDR76's Avatar
Received 1,603 Likes on 1,021 Posts
For brakes, I would either do them myself or take them to an independent shop. The dealer is quite expensive for these.
Old 10-26-15, 01:38 PM
Yurka
Yurka's Avatar
I see, could you suggest some good brakes? I've never had them done on rx so I'm hesitant over which to buy
Old 10-26-15, 01:52 PM
vlad_a
vlad_a's Avatar
You could take a nice break in the Atlantic City, since you're so close by.
But if you wanted to replace your brakes, you can't go wrong with OEM.
Just buy parts online and DIY. I used discounttoyotaparts.com to buy from.
This is something you learn how to do once and you'll wonder why you paid someone else to do it for you.
Old 10-26-15, 01:59 PM
Clutchless
Clutchless's Avatar
Received 1,096 Likes on 935 Posts
If it is your first time read and watch the videos on http://www.toyotanation.com/forum/12...fications.html
as the 2nd gen highlander has the same brake system. Any independent garage can install brakes and some will let you bring your own pads or will get them for you from the dealer.
Old 10-26-15, 07:29 PM
afpj
afpj's Avatar
This post had nice pics too
https://www.clublexus.com/forums/rx-...t=Front+brakes
Old 10-27-15, 12:14 PM
Yurka
Yurka's Avatar
thank you guys, so i could easily go with original pads, no need to go fancy right?
Old 10-27-15, 12:26 PM
vlad_a
vlad_a's Avatar
From my experience, OEM pads and rotors worked out better than aftermarket, both quality and longevity.
Old 10-28-15, 06:38 AM
GSteg
GSteg's Avatar
Brakes are definitely a DIY on this car. Just make sure you compress the piston slowly. Nothing should be forced.
Old 10-28-15, 07:24 AM
lexus114
lexus114's Avatar
not to be ****, but its brakes not breaks. a break is what you take at work....
Old 10-28-15, 09:27 PM
Yurka
Yurka's Avatar
^^ lol my bad, i just realized i misspelled it after you pointed it out..
Old 10-29-15, 08:00 AM
kitlz
No, I don't play soccer!
kitlz's Avatar
And I changed the title for you. The more information, the better
Old 03-16-16, 10:42 AM
Yurka
Yurka's Avatar
So i want to order brakes today, anyone can suggest good/reliable website to order them from? I need front and rear pads and front rotors. I went to ****************** but none one the brake kits have any reviews on them.
Old 03-16-16, 11:17 AM
Clutchless
Clutchless's Avatar
Compare prices (and ease of navigation) at these 2 sites for OEM parts
http://www.lexuspartsnow.com/
http://irontoadparts.com/Lexus/
You need to know if your vehicle is made in Japan or Canada. If the first digit of the VIN is J then it was made in Japan. Otherwise, Canada.
Old 03-16-16, 07:54 PM
Yurka
Yurka's Avatar
im sort of lost on those two lol... buut thanks
Quick Reply: 3RX Brake Replacement
