Tire warning alert
Old 10-06-15, 01:39 PM
axson
axson's Avatar
Cool Tire warning alert
I have a 2010 LEXUS RX350. I followed the instructions to reset the tire low pressure warning light. It blinked three times but did not stay off. I have 34psi in each tire including the spare.
Can the sensors in the valves be checked to see if one of them is bad?
Any suggestions?
Old 10-08-15, 09:12 AM
alex1372
alex1372's Avatar
Did you try to drive? I believe it requires some movement to sync the sensors
Old 10-09-15, 06:48 AM
NVAKeith
NVAKeith's Avatar
Double check the pressures with a different gauge.
I had one sensor die around the five year mark. Dealer replaced it and the rest have been fine. You say you have a 2010, that's a third gen, check their forum for specifics on how to test the sensors.
https://www.clublexus.com/forums/rx-...2010-2015-212/
Old 10-12-15, 05:46 AM
axson
axson's Avatar
Default tire warning light alex1372
I found out by mistake that after I drove the sinc worked and the warning lite went out. Thanks alex1372.
Noelma
CT 200h Model (2011-2017)
08-24-21 08:38 AM
dtaylor
GX - 1st Gen (2004-2009)
03-13-17 10:24 AM
sderman
04-27-16 08:12 AM
andy350
09-04-13 11:51 AM
Lac
21
02-18-06 07:38 AM
Quick Reply: Tire warning alert
