Oil filter 2013 rx
Oil filter 2013 rx
Anyone have filter number for the toyota filter that will fit my rx, looking at ebay to grab a few to do my own oil changes, thanks
Almost all Toyotas with the 3.5 V6 take this oil filter. 04152-YZZA1. It may be cheaper/easier to go to the local Toyota dealer and get your Toyota 0W-20 oil at the same time. It is made by Mobil to Toyota specifications and is a bit more robust than Mobil 1 0W-20 for almost the same price. Although your engine probably won't know the difference between it or Mobil 1 or Pennzoil synthetic 0W-20. Also pick up the drain pan washers at the same time, although I did buy a pack of 10 on eBay for really cheap. Again, most Toyotas take the same washer.
http://lexus.sewellparts.com/accesso...2013/2532.html
Also this is a canister oil filter and you should get this specific wrench to remove the housing, a typical oil filter wrench will not work. Get the Assenmacher TOY 640 tool. Get it at Amazon, the dealer may not have it, or may deny it exists.
You just stick a big socket on the end to remove or install it. The canister has 2 rubber O rings you replace with new ones that come with the new filter cartridge. Instructions will be in the package.
Amazon.com: Assenmacher Specialty Tools TOY 640 Oil Filter Socket Wrench for Toyota/Lexus: Automotive
