Tire Size
Old 07-16-14, 10:24 PM
skyline03
skyline03's Avatar
Default Tire Size
Currently i have 235/55/R19 on my RX but was wondering can i get 245/50/R19??
Will there be any issues?
Thanks
Old 07-17-14, 05:40 AM
SteveCraig
SteveCraig's Avatar
The 245 @ 28.6" is slightly shorter than the 235 @ 29.2".
Not sure how the speedo receives it's signal but you may see a minute (2-3%)difference in speedo accuracy.
Old 07-17-14, 02:54 PM
skyline03
skyline03's Avatar
What does this mean sorry? Will it be safe?
Thanks
Old 07-17-14, 03:00 PM
SteveCraig
SteveCraig's Avatar
The tire height of the tire relates to the circumference of the tire, eventually leading to the number of revolutions per mile. This is why I noted a possible small difference in speedo vs. actual speed.
Check with Lexus about the widest tire you can mount on your rims.
Otherwise, no issues.
Old 07-18-14, 07:48 AM
Clutchless
Clutchless's Avatar
Received 1,096 Likes on 935 Posts
You want 255/50/19 which is almost exactly the same diameter as the stock 235/55/19. There is only one tenth of a millimeter difference in size and that is so little that given manufacturers design differences and manufacturing tolerances, they are the same diameter.
The wheel design widths acceptable for this size are 7 to 9 inches. The factory wheel is 7.5 inches. They will fit.
You can find such charts all over the internet.
Old 07-22-14, 12:36 PM
vlad_a
vlad_a's Avatar
I can confirm that 255 will clear suspension components. I run 255s on an 18x8" wide rim as my winter set.
BIG TY
11-23-08 06:56 AM
beachboy23
Wheels, Tires & Brakes Forum
05-23-07 12:57 PM
Mike
06-06-01 09:14 PM
Quick Reply: Tire Size
