What fuel grade is everyone using on their 2012-2015 RX?
Old 04-28-12, 05:37 AM
  #31
Marqevans
Marqevans's Avatar
Wow fifty cents a gallon difference? I think we only pay about .24 more. Which is only about 5 percent.
Old 04-28-12, 07:19 AM
  #32
svofan1
svofan1's Avatar
...sorry, I made a mistake...I just cked at my local gas station(Shell) and it is $3.79 for regular and $4.16 for premium...still $.35 difference, as of today....<S>
Old 04-28-12, 07:36 AM
  #33
MX5NES350
MX5NES350's Avatar
Originally Posted by MARQEVANS
I guess the question is did they actually make changes to the engine in 2012 or did they just tell owners to use regular like owners of previous years RX's were doing anyway without performance issues?
This is about as close to an answer you will receive:
https://www.clublexus.com/forums/7037262-post9.html
Eric
Old 04-28-12, 08:05 AM
  #34
svofan1
svofan1's Avatar
..very interesting......but if I had 2011 model I will have some concern with prolonged "pinging", it is not only a nuisance but could also cause long term damage to the engine, but since the letter came from "the horse's mouth" we should take it as it and save it just in case....that is what I would do....
Old 04-28-12, 08:14 AM
  #35
MEP7557
MEP7557's Avatar
So the answer is Yes and Yes. It may not be leaps and bounds but, using Premium does make a difference. The difference between reg and premium here is 20 cents. Never in my 40 some yrs of driving have I put reg gas in any car I have owned. Just a thing with me and I am not in the poor house for doing so.
Old 04-28-12, 08:35 AM
  #36
dctex99
dctex99's Avatar
Having driven and studied cars since 1960 I have had engineers in recent years say the engine will adjust for Premium and put out more power and better gas mileage. I see it as every time I drive to Las Vegas I put in premium and I only drop from High gear on two hills and I DO get better gas mileage!!! Around town I put in Regular. By the way, I also always put in Top Tier gas when buying premium!! www.toptiergas.com of which Lexus was one of the first to join in!!
Old 04-28-12, 10:31 AM
  #37
UCSB
UCSB's Avatar
Why not just run your RX on premium for a few months and see if you notice any difference? The cost difference between regular and premium is trivial.
Old 04-28-12, 11:34 AM
  #38
svofan1
svofan1's Avatar
do you really think so?.....I guess for some is and for others no so trivial...it all depends where you are and how much you drive...and as far as trying both grades, I have and the difficulty is that the mileage driven is not identical in comparison...hard to replicate...
on another note, I am not trying to be controversial...just a different opinion...
Old 04-28-12, 08:04 PM
  #39
MEP7557
MEP7557's Avatar
Trivial is a good word after spending $50 k on a car.
Old 04-28-12, 09:17 PM
  #40
Dawa
Dawa's Avatar
when a factory car requires premium gas it is because the higher octane in the premium gas prevents detonation (where the fuel/air mixture combusts BEFORE they are ignited by the spark plugs.) i think i read that this is because the higher octane keeps the cylinders cooler.
87 vs 89 vs 91/93 giving more or less power has been argued/bickered/etc about for years and years, and will continue to be argued about.
in many peoples opinion, the gain in power from these lower to higher grades is negligible. you really have to start going much higher than that to truly see power.
the only thing that could be suggested would be to buy 'top tier' gas, which is supposed to have higher amounts of detergents to keep your engine running 'cleaner.' (ie 76, chevron, shell, etc) cheap gas is usually not good gas.
Old 04-29-12, 07:17 AM
  #41
svofan1
svofan1's Avatar
the only thing that could be suggested would be to buy 'top tier' gas, which is supposed to have higher amounts of detergents to keep your engine running 'cleaner.' (ie 76, chevron, shell, etc) cheap gas is usually not good gas.[/QUOTE]
Totally agree....
Old 04-29-12, 04:14 PM
  #42
GrandSedanFan
GrandSedanFan's Avatar
False. If I put premium in a car with a moderate compression motor, there is no sensor that detects the octane level of the gas and ADDS timing. Can't do it with the O2s either. If I put regular in a car designed for premium, the knock sensors will sense knock and pull timing.
The idea that the cars knows what kind of gas is in it is something I've read numerous times on the internet and speaks to a lack of knowledge of engine management.
High compression and forced induction motors generally require premium. They need it to prevent knock. A Corolla....just doesn't. You're throwing away the money.
I've had my sales rep tell me repeatedly that my 2010 RX350 doesn't need premium. The 2GR-FE has 10.8:1 compression, which is high for regular. I've done test runs with regular gas and seen no difference, but I'd rather just put premium in it. I plan on keeping the truck after the lease is out.
Old 04-29-12, 05:32 PM
  #43
Marqevans
Marqevans's Avatar
Makes sense that the sensor would be designed to check for a problem as opposed to looking for something positive to adjust to.
Old 04-29-12, 06:16 PM
  #44
markrivers
markrivers's Avatar
Amen to that!
Old 04-29-12, 08:57 PM
  #45
LexRexBlue
LexRexBlue's Avatar
On previous RXs they told me I could use regular. After 4 years the 400h started getting bad mileage and poorer performance and I had to switch to premium even though I always used top tier gas. But on the 2010 they said I really needed to use premium (same service advisor). Ironically, at my last trip to the Shell station the attendant was surprised when I requested premium. Hmm I wonder what other RX owners do. There are zillions in town,
Quick Reply: What fuel grade is everyone using on their 2012-2015 RX?
