2010 RX350 Front and Rear Door Seal Problem
Old 12-07-13, 06:47 AM
2008M3
2008M3's Avatar
Default 2010 RX350 Front and Rear Door Seal Problem
Can anyone check to see the following:
1. The front inner window/door seal near the side mirror is becoming deformed
2. The rear outer window/door seal near the back of the rear passenger door coming apart
Please take pictures so we can compare
Attached Thumbnails 2010 RX350 Front and Rear Door Seal Problem-lexus-front-door-seal.jpg   2010 RX350 Front and Rear Door Seal Problem-lexus-rear-door-seal.jpg
Old 12-07-13, 10:39 PM
ThChinaman
ThChinaman's Avatar
My rear window seals look somewhat similar to yours. It's currently too cold and dark out to take a photo so I'll get you one tomorrow. I discovered mine a while back but when I checked out a few other RX's, they were all like that so it's one of the few things I just let go. It looks as if the rubber seal was not long enough to go all the way around so at the corners it sticks out a bit. If they were backed up to fit properly into the windows, the ends on the opposite corner of the window would be too short.
Old 12-08-13, 06:47 AM
2008M3
2008M3's Avatar
What about the inside of the front window? it's like that on both sides of mine
Old 12-16-13, 08:20 AM
2008M3
2008M3's Avatar
Anybody? I'd like to know if I should bring this up to the dealer or if it is normal and like this on all RX350's as my car is almost out of warranty.
Old 12-16-13, 02:08 PM
RickC5
RickC5's Avatar
FWIW, our 2010 RX, built in Japan in 02/09 doesn't look deformed like that. The seals look fine to me.
It doesn't hurt to ask. Al the dealer can say is no.
However, it does seem like a lot of road noise comes from the B-pillar, and I haven't found the source of that yet.
Old 12-16-13, 09:18 PM
2008M3
2008M3's Avatar
Would you take some pictures of the same spots to show me? That would really help, then I can print it out and show the dealer in case they don't have a 2010 on the lot to compare with. They always give me the crap about how they can't only compare 2010 with 2010 and not 2011 or 2012.
Old 12-16-13, 09:21 PM
capcap
capcap's Avatar
The seals on my 2010 Canada-built also do not look squashed like that.
Old 01-21-14, 08:37 PM
2008M3
2008M3's Avatar
can anyone post a picture of their car?
Old 01-21-14, 09:01 PM
JDR76
JDR76's Avatar
Received 1,603 Likes on 1,021 Posts
I am not seeing any deformed seals around the windows. Not sure if this photo helps you or not.
Attached Thumbnails 2010 RX350 Front and Rear Door Seal Problem-img_3235.jpg
Old 01-21-14, 09:05 PM
JDR76
JDR76's Avatar
Or try these:
Attached Thumbnails 2010 RX350 Front and Rear Door Seal Problem-img_3237.jpg   2010 RX350 Front and Rear Door Seal Problem-img_3238.jpg   2010 RX350 Front and Rear Door Seal Problem-img_3239.jpg
Old 01-23-14, 01:05 AM
ThChinaman
ThChinaman's Avatar
Sorry. Totally forgot to upload photos. Here are mine. IIRC, my front doors are fine.
Attached Thumbnails 2010 RX350 Front and Rear Door Seal Problem-5d3_4015-1.jpg   2010 RX350 Front and Rear Door Seal Problem-5d3_4017-2.jpg
cjduryea
11-03-18 03:52 AM
texves
06-11-15 06:57 PM
e-man
02-10-06 09:52 AM
ap0718
04-10-02 02:26 AM
Quick Reply: 2010 RX350 Front and Rear Door Seal Problem
