Strange beep every 15 minute or so
Old 10-29-13, 06:00 PM
kitlz
No, I don't play soccer!
kitlz's Avatar
At least you can laugh about it. And look at the bright side, maybe someone else has the same problem and you just solved it for them
Old 10-30-13, 06:00 AM
Mors
Mors's Avatar
Glad you found it!
Old 11-08-14, 03:07 PM
melliott54
melliott54's Avatar
Default Not my RX330
After being driven nuts from the off and on beeping in he garage of which sounds just like the Lexus, I discovered it was the Verizon FIOS battery . Thanks to someone else of this forum that also found out it was not there vehicle beeping but another device.
Old 11-08-14, 04:30 PM
kitlz
kitlz's Avatar
Another happy ending
Old 11-08-14, 04:56 PM
raylor4
raylor4's Avatar
Thanks everyone for chiming in
Thanks for the closure and the pun.
Old 12-23-19, 05:01 AM
Paulyno1
Paulyno1's Avatar
Exclamation Beeping sound every 30 seconds with car off and locked
Please advise on what to do. I have a 2012 450h and there is a single beep that is occuring every 30 seconds since last night. Could it be my battery?
Old 05-05-20, 12:39 PM
ADStotts
ADStotts's Avatar
Default Not my RX 350 either
OMG!! Thank you so much for posting this question. I had the same problem with my Lexus RX 350 beeping every 30 seconds. It was driving me nuts and I couldn’t figure it out so I took it to the dealership. They checked and checked and could not find the problem. Thanks to this article I went back out to my garage and continued to hear the beep even though my car was still at the dealership. 🤔. After a short investigation I discovered the replacement battery on my garage door opener was going bad.
Again thank you so much for posting this question and solving my issue. Now I just have to convince my mechanic I was having a senior moment with a blond moment attached for good measure!😉
16NX200T (10-29-20)
Old 10-27-20, 08:19 AM
16NX200T
16NX200T's Avatar
Did you find out the cause of the beeping every 30 seconds? My 2016 NX200T just started doing that as well.
Old 10-27-20, 09:57 AM
mcomer
mcomer's Avatar
Do either of you have any warning lights on?
Second key left inside?
Recently replaced battery or jump start?
(Neither the RX two row or NX will have the incessant chime of
the 3rd row RX and GX when the seat is not fully up or down.)
Old 10-28-20, 06:37 AM
16NX200T
16NX200T's Avatar
No warning lights are on, no key left inside and did not recently change or jump start the battery. Wondering if maybe disconnecting the battery and reconnecting will help reset the system, but I have my doubts about it being that easy. Is it likely to be a faulty sensor?
Old 10-28-20, 08:01 AM
mcomer
mcomer's Avatar
Anything obstructing your back door (hatch) preventing it from closing fully?
Sunroof not quite closed?
Old 10-28-20, 08:51 PM
16NX200T
16NX200T's Avatar
Nothing is obstructing the trunk (it's closed) and the sunroof has not been opened in months.
Old 10-29-20, 04:37 PM
16NX200T
16NX200T's Avatar
So I was reading other posts and saw that someone mentioned an issue with their garage door opener, so I decided to check that out and of course that's what it ended up being.
texaslexii
GS F (2016-present)
11-21-18 08:12 AM
msports205
10-09-12 04:32 PM
GRPFAN
RX - 3rd Gen (2010-2015)
03-23-12 07:56 AM
AndysIS
01-17-12 08:49 PM
USCRugby
03-09-08 03:47 PM
Quick Reply: Strange beep every 15 minute or so
