1st inspection
Old 07-22-13, 02:37 PM
Yurka
Yurka's Avatar
Default 1st inspection
Today was the 1st time i went to the dealership for my oil change and car inspection, on a receipt they put that they did oil & filter change, checked wheel alignment and did 21-point inspection. I was in a hurry for work so i left the second they told me my car was ready, yet im curious what is 21-point inspection, what do they check, ive never done it before, or at least i dont know about it.
Old 07-22-13, 04:12 PM
mklemovitc
mklemovitc's Avatar
Default 21 points
From the interwebs...
Most 21 Point Inspections are similar and consist of the following;
(1) Check Tire Pressure
(2) Check Brake Fluid Level
(3) Visually Inspect Exhaust System
(4) Check and Fill Washer Fluid
(5) Visually Inspect Shocks/Struts
(6) Check Oil Level
(7) Check Steering System
(8) Inspect Undercarriage (for leaks or Drips)
(9) Visually Inspect Belts
(10) Check and Fill Lubrication Points
(11) Visually Check Hoses
(12) Check Radiator Level
(13) Visually Inspect Tires
(14) Check Radiator Fluid Protection
(15) Check Air Filter (and Breather Element if Installed)
(16) Check Acid/Base Concentration of Radiator Fluid
(17) Check P/S Fluid Level
(18) Check Turn Signals
(19) Check Transmission Fluid Level (on Automatic Transmission
(20) Check Lights
(21) Inspect the Drive Axle Condition on FWD Vehicles OR Differentials and/or Transfer Case on RWD & 4WD Vehicles
Old 07-22-13, 06:34 PM
Yurka
Yurka's Avatar
They dont check breaks do they?
lexus-is2
11-16-18 07:16 AM
kingkong5
Maintenance
01-04-06 06:15 PM
GS300Rich
05-22-05 08:20 PM
nolimit94t
General Classifieds
02-19-03 05:50 PM
Quick Reply: 1st inspection
