Three punctures in glove box door
Old 03-29-13, 09:48 AM
Marqevans
Marqevans's Avatar
Default Three punctures in glove box door
My 2012 mysteriously has 3 puntures in the gray leather glove box door. Where is the cheapest place to get a replacement or the best place to get it repaired in the Chicago area.
Old 03-29-13, 10:54 AM
DunWkg
DunWkg's Avatar
Did you check with your dealer?
Or perhaps do a search in the Chicago Regional forum and see if those folks have any experience with a leather shop.
Old 03-29-13, 01:07 PM
UCSB
UCSB's Avatar
Check with local dealers to get a baseline on price and part numbers. A local body shop may also be cheaper. Then check with forum sponsor Sewell's where you can get a ClubLexus discount. Use the part number to do a web search. If you really mean cheapest, then you can search the used parts dealers online or monitor ebay.
I have repaired a few problems on my boat with very good results. They have inexpensive kits you can get for vinyl/leather repair. Basically, you mix material to right color and apply it to damaged area. Then use one of the included texture patches to apply a similar texture. This may be good enough depending on your goals. A leather repair shop might also be a possibility if you are not the DIY type. It will only cost $10 or $15 to try and repair it yourself, if that fails you can pursue the other options.
Mirza90
ES - 5th Gen (2007-2012)
07-15-18 04:02 PM
LexPaul
Automotive Care & Detailing
05-06-10 09:08 AM
knguyen
02-17-10 12:22 AM
anonymous
RX - 1st Gen (1999-2003)
07-28-03 02:45 PM
Quick Reply: Three punctures in glove box door
