2010 RX350 Smart Key ?
Old 02-15-13, 02:23 PM
Johncedina
Johncedina's Avatar
Default 2010 RX350 Smart Key ?
I found used smart key at ebay
every numbers are same as my car like these
FCC ID: HYQ14ACX
IC:1551A-14ACX
COFETEL RLVDE1408-0265
DENSO 14ACX.
question is
Do I have to re-program ? need to go deal or locksmith ?
can they or will do re-program ? how much ?
key is amost $100, I just want to make sure I can use it before i buy.
Old 02-15-13, 04:14 PM
corradoMR2
The pursuit of F
corradoMR2's Avatar
I once asked my salesman if I lost my key it would cost about 400$ from Lexus to e replaced. I lso asked if I bought it online, if Lexus would be able to program it. He said yes.
Ask your dealer/service dept just in case and if so, they will charge you for programming and figure a 1 hr labor charge ($100+). Good luck.
Old 02-15-13, 05:44 PM
TomL51
TomL51's Avatar
FCC ID: HYQ14ACX
IC:1551A-14ACX
DENSO 14ACX.
question is
I did the same thing. Go to locksmith. Works fine.
Old 02-15-13, 07:15 PM
UpodJohn
UpodJohn's Avatar
If the numbers are the same the used Smart key can be re-programmed to your vehicle.
The metal key inserted in the used item from eBay will not match your locks.
Old 05-02-14, 09:01 AM
Elly
Elly's Avatar
Default Key code info
Where can i find the key codes you listed?
Old 05-03-14, 12:47 PM
zmel
zmel's Avatar
You should find it in the back of the key fob, remove it from the leather pouch (if you have one)...
taihwa
ES - 5th Gen (2007-2012)
12-09-17 11:22 AM
khoality
GX - 1st Gen (2004-2009)
02-02-17 08:09 PM
lexasaur
ES - 6th Gen (2013-2018)
08-20-16 08:43 AM
RhoXS
06-30-09 09:02 AM
nickj88
12-27-08 01:48 AM
Quick Reply: 2010 RX350 Smart Key ?
