will 2013 rx 350 or F bumper fit 2010?
Old 06-14-12, 01:17 AM
rx350rider
rx350rider's Avatar
Default will 2013 rx 350 or F bumper fit 2010?
Does anyone try to install the 2013 rx350 or F bumper on 2010 rx 350?does it fit? if so. can you please tell me how much does it cost and how to do it, where to buy? thank
Old 06-14-12, 06:38 AM
DINH300
DINH300's Avatar
It should fit because the headlights hood and fenders are the same so all you have to do is go to the dealer and buy the bumper, grill, mud guards, wheel barrel lining and under piece for the radiator and everything should fit like factory. it will probably cost you around 2500-3000 after paint and all just to get it to look like 2013.
Old 03-20-13, 06:17 PM
Odko
Odko's Avatar
hey there, did you replace the 2013 bumper to your 2010 model RX yet? cause I wanna do that too, thanks
Old 03-20-13, 06:24 PM
Odko
Odko's Avatar
hi, I asked dealer to replace 2013 RX bumper on 2010 RX model, but they don't know if it fits. Is there anyone know about that? what if it doesn't fit, right? I don't wanna waste my money. Pls help for that. Thanks
Old 03-20-13, 07:43 PM
Cruiter
Cruiter's Avatar
If you could realistically even do that (pretty sure you can't with headlight changes and such) you'll destroy your resale with a mod like that. But the total price tag will actually make you just want to buy a 2013. It's not just bumper cover, it's the actual bumper underneath, grill and parts, and if you have the AFS headlight system it won't work as the 2013's don't have it and aren't wired for it.
Old 03-21-13, 02:13 PM
cless
cless's Avatar
any news? I am interested on "changing" my 2010 to 2013
Old 03-21-13, 07:59 PM
Sevn86
Sevn86's Avatar
if your talking about just changing out the bumper and grille then it should most likely work. i don't have the funds but i do want to get the f-sport front bumper for mine. The fenders, hood, and lights have the same shape its just the bumpers that are different and you might need a couple other parts like wheel liners and such. I say the lights are the same because the shape hasn't changed they just redesigned the inside of the lights, added LED's and took away the AFS feature but that shouldn't matter if your only gonna change the bumper.
Old 03-21-13, 09:26 PM
jbounnoi
jbounnoi's Avatar
ive messaged Darrel about this from Sewell.. he says its not possible.. without swapping the headlights.. and they also dont have a solution for the headlight swap either..
i really want to swap to the f-sport bumper though.. would try and buy the parts but got some other stuff on the top of the list before this!
Old 05-05-13, 09:12 PM
Sevn86
Sevn86's Avatar
Keep us posted when and if you do.
Old 09-04-14, 07:34 AM
acitydwelr
acitydwelr's Avatar
was this retrofit ever confirmed ?
Old 09-04-14, 07:36 AM
acitydwelr
acitydwelr's Avatar
never mind. answer is here: https://www.clublexus.com/forums/rx-...ml#post8418897
Old 09-05-14, 07:27 PM
mullen00
mullen00's Avatar
My wife was backing out of a parking spot and clipped a concrete light pole with the right front corner of our Matador Red 2010 RX. I really like the new spindle grille so I asked the body shop if it was feasible to install a 2013 front bumper and what it might cost above the insurance payment. After some research my body shop thought it was feasible and would cost about $1000 extra. I told them to go ahead. Well it turned out to be quite a challenge because the headlights on the 2010 are a little taller and the bumper would not fit properly. After a bunch more research and some after market 2013 RX non-HID headlights, the body shop was able to make it work for $4400. The 2013 bumper has a lot of additional grille parts and backets that they had to order. They had to modify the 2010 wiring harness plugs to fit the 2013 light sockets to make the headlights, turn signals and running lights work, however, the LED running lights are not yet hooked up because the socket is a 5 pin while the wiring harness is a 2 pin plug. At a later date, I'll check with Lexus to get an estimate for hooking up the LED running lights if feasible. I had some different painting done on the bumper by having the shop paint the portion of the bumper black between the upper and lower grille sections and also paint the upper grille black. I really like the way it turned out with the different paint job. Since the 2013-2015 RX does not come in Matador Red, this is a unique RX. At least I've never seen a Matador Red RX with a spindle grille.
Attached Thumbnails will 2013 rx 350 or F bumper fit 2010?-rx-350-accident.jpg   will 2013 rx 350 or F bumper fit 2010?-rx-spindle-grille.jpg
Old 09-08-14, 07:45 AM
oohpapi44
oohpapi44's Avatar
looks good but please tally up all your receipts when this is done and working 'properly' and lets see what the final number is.
Then need to add in how ever much the vehicle would lose on resale for a full tally.
Doesn't seem like it's going to be worth it in the long run.
But can't take anything away from the workmanship... Props.
Old 09-08-14, 07:56 AM
vince22
vince22's Avatar
Looks fantastic....I think its OK if you don't have plan to sell/trade it, but I would have put F-sport for that amount you have spend..just me.
Old 09-08-14, 08:21 AM
oohpapi44
oohpapi44's Avatar
Either way you're spending a considerable amount to imitate something you're not.
Quick Reply: will 2013 rx 350 or F bumper fit 2010?
