Side step install help
Old 05-19-11, 05:37 PM
sweetboy02
sweetboy02's Avatar
Originally Posted by newowner7
Did the installation require any cutting into the body or guard? Interested in doing but worry about damaging the car.
No cutting or drilling. Just put them on and tighten the bolts
Old 05-20-11, 11:03 AM
newowner7
newowner7's Avatar
Can you tell me the brand you purchased. I have a 2010 RX350. Is that the same model?
Old 05-20-11, 05:57 PM
sweetboy02
sweetboy02's Avatar
Answer in page 1 Broadfeet. Mine and yours are twin
Old 05-22-11, 10:13 PM
newowner7
newowner7's Avatar
thanks for your help.
Old 05-23-11, 12:51 AM
stw2046
stw2046's Avatar
Smile
There you go!
Old 05-23-11, 04:50 AM
sweetboy02
sweetboy02's Avatar
Originally Posted by stw2046
There you go!
Beautiful. I also saw this on the street. Much better looking than the step bars I have.
Old 05-23-11, 04:56 AM
jclem
jclem's Avatar
There you go!
Any chance you could post more pics of your running boards? I've been considering the ones you have or the all black version. My RX is Black Sapphire. Thanks
Old 05-23-11, 08:58 PM
stw2046
stw2046's Avatar
Thanks Sweetboy02!
You know what.. your car blings awesome too!!!
Old 05-23-11, 09:06 PM
stw2046
stw2046's Avatar
Smile
Definitely jclem!
I think they both will look great on the black sapphire. I'd probably try to match whatever rim color you have.
If my memory is serving me, I think there is a small price difference between them too. Your call bro.
PM me with your email if you need more better pics, cuz CL will only allow pics size from my phone.
Old 05-23-11, 09:14 PM
the.wong.k
the.wong.k's Avatar
the romik brand ones do require cutting of the plastic underneath for a bracket and bolt
Old 05-24-11, 05:15 AM
sweetboy02
sweetboy02's Avatar
Thanks Sweetboy02!
Haha, Thanks, I'm looking to buy 4 chrome wheels. Will be more bling Blings.
Old 05-24-11, 03:37 PM
newowner7
newowner7's Avatar
Thanks The.wong.k. I was able to get a hold of a installation pdf for romik and Aries and you are right. They require cutting into the rock guard. I am going to check out the one that Sweetboy02 suggested and see (Broadfeet).
Do you have a romik? how you like it and was it hard to install?
Old 05-10-12, 09:42 AM
nvn2005
nvn2005's Avatar
Default Broadfeet installation
I just bought the broadfeet side steps. It does not come with any installation instruction. can someone post a picture where are the brackets suppose to mount?
It came with 4 brackets, 2 long brackets for the front and 2 short brackets for the rear, I have no ideal where to put the bolts. These bolts have tab.
Would help me out a lot if i know where are the brackets location.
Thanks
Old 05-10-12, 10:27 AM
sweetboy02
sweetboy02's Avatar
Thanks
Yup they came with the instruction for the Highlander. I had to call Broadfeet, so they sent me couple pix where to mount, you have to crawl under the car then put the step bar in place then you'll will see where to mount. Took me 3-4 hours to get them in. If you have a second person help much faster because you don't need to hold the "heavy step bar" and bolt them in at the same time. I scratched my back a bit. And MAKE SURE you wear Goggle Glass
PS: You have to mount the bracket in place first
Old 05-10-12, 10:49 AM
nvn2005
nvn2005's Avatar
I did exactly what you suggested, I aligned the side steps straight with the front and back doors then placed the brackets where it suppose to mount but no screw holes nearby align with brackets screw hole. Do you have to drill a hole?
Do you still have those pix broadfeet send you? Can you post them?
Thanks
Quick Reply: Side step install help
