How to remove Roof Racks - Page 2 - Club Lexus Forums
Thread Tools Search this Thread
Old 11-18-11, 09:52 PM   #16
MEP7557
MEP7557's Avatar
All the parts are self sealing. There should be a gasket on the bottom of the bracket and rubber washers on the bolts. That's all you need.
MEP7557 is offline   Reply With Quote
Old 11-19-11, 05:14 AM   #17
AlexB
Thanks MEP, I hadn't noticed those gaskets.
AlexB is offline   Reply With Quote
Old 11-19-11, 08:35 PM   #18
CapeDave
Funny, this was the first thing I noticed on the showroom floor. I HATED the roof racks! I asked about them and he looked at me like I was the nutty one They would be coming off immediately if I make the purchase.
Prob get 1 MPH better without all that drag
CapeDave is offline   Reply With Quote
Old 11-21-11, 08:17 PM   #19
CapeDave
I actually meant 1 MPG better
Old 04-14-12, 04:48 PM   #20
joeh80
joeh80's Avatar
Default Roof rack plugs
Anyone got a close up picture of how the plugs look with the racks removed?
joeh80 is offline   Reply With Quote
Old 04-14-12, 07:18 PM   #21
MC5Wes
Registered User
Default Roof Rack
Heres mine with the roof rack removed.
How to remove Roof Racks-rx-1-.jpg   How to remove Roof Racks-rx-2-.jpg   How to remove Roof Racks-rx-5-.jpg
MC5Wes is offline   Reply With Quote
Old 05-21-12, 10:53 PM   #22
Sevn86
Sevn86's Avatar
I personally like the look of the roof rails.
Sevn86 is offline   Reply With Quote
Old 05-22-12, 01:43 PM   #23
kitlz
No, I don't play soccer!
kitlz's Avatar
I have removed posts about buying/selling the roof rails. Please post them in our classifieds section. Thank you.
kitlz is offline   Reply With Quote
Old 05-22-12, 02:25 PM   #24
gqscholar
Quote:
I like them too, on white with alloy wheels. They match the wheels
gqscholar is offline   Reply With Quote
Old 05-09-13, 12:08 AM   #25
satnav
satnav's Avatar
Quote:
Originally Posted by AlexB View Post
Be careful removing the bolts that hold the roof rails on. There are two at each end, and the nuts are mounted on a flat plate inside the roof, and project up through two holes. Those plates are held in place by a spring clip also hidden inside the roof. I cursed and swore through what should have been a simple half hour job to remove both rails when one of those spring clips popped off while undoing the bolts, allowing the retained nuts to drop down inside the roof. I was eventually able to pry down the headliner above the drivers door and force my hand inside to find the parts, pushing the nuts back up and capturing them with a bolt - never did get the spring clip back on, there's not much room to work, and there's an airbag up there! Taking off the grab handle didn't help either - just a tip - you don't need to disassemble the grab handle to take it off! To add insult to injury, the covers that my dealer sold me were too short and too wide, must have been for an earlier model, but he swears he used my VIN number when looking them up. Roof rail reinstalled, parts returned for full refund, much wiser RX owner who's now completely happy to leave those ugly rails alone.
I plan on removing my roof racks later this week. But after reading this post I am getting very worried. Is this a common problem? And what exactly should I do to prevent this from happening?
So to prevent this if I remove one screw and make sure a second screw is in place but loose then there is no chance that the bracket will fall in.
thanks
satnav is offline   Reply With Quote
Thread Thread Starter Forum Replies Last Post
Roof rack removal thelew67 RX - 3rd Gen (2010-2015) 12 05-21-14 03:32 PM
RX350 Roof Rack Removal Esmeralda RX - 3rd Gen (2010-2015) 36 11-07-12 03:49 AM
How to remove roof rack crossbars? prowler97 RX - 2nd Gen (2004-2009) 13 12-06-10 12:43 PM
Roof Rack Removal?... NCCSG91 GX - 1st Gen (2004-2009) 6 11-30-10 09:33 AM
GX 470 roof rack removal 1695 GX - 1st Gen (2004-2009) 5 03-02-06 09:45 PM
Tags
2010, 2011, 350, crossmember, instal, lexus, luggage, rack, racks, remove, removing, roof, rx, rx350, rx400h
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Copyright © 2000-2016 Internet Brands, Inc. All Rights Reserved
