differential fluid change
Old 03-21-17, 05:50 PM
Jrosenobs
Jrosenobs's Avatar
Default differential fluid change
80k mile son 2010 RX350 - dealer said i should change differential fluid. The invoice at the end said "customer requested fluid change" - inaccurate statement, so i want to know - when do i need to change that fluid?
Old 03-21-17, 06:46 PM
BlackLexRX
BlackLexRX's Avatar
Check your manual it will tell you. Believe mine says 100k initial change for regular interval 50k initial change for severe duty. I did mine at 70k when I bought it. Really easy to do, just 2 plugs and no need to jack it up, just get under the rear and do it. Check the 3rd Gen forums. This is the 2nd Gen. Similar drive train, but yours is different.
https://www.clublexus.com/forums/rx-...2010-2015-212/
Old 03-21-17, 09:56 PM
Lexuswiz
Lexuswiz's Avatar
BlackLexRX is spot on, my pro tip is to always take off the fill plug first before draining the fluid just in case you for some reason can't get it off or strip it.
not2late
RX - 4th Gen (2016-2022)
218
04-10-24 02:13 AM
mcfancy
RX - 3rd Gen (2010-2015)
12-30-16 07:55 PM
GS4_Fiend
Performance
03-28-09 09:30 AM
stl2chi
GX - 1st Gen (2004-2009)
04-06-07 09:35 AM
400 Degrez
Performance
01-12-07 11:01 PM
Quick Reply: differential fluid change
