Could spark plugs replacement lead to Valve Cover Gasket Replacement.
Old 02-24-17, 01:38 PM
hurrikane
hurrikane's Avatar
Default Could spark plugs replacement lead to Valve Cover Gasket Replacement.
Hello, probably a stupid question from non-car guy, but I'm curious. My car is Lexus RX330 2005. My mechanic replaced spark plugs about 3 months ago, I think car mileage was ~140K at that time. Today, mechanic said that I need to replace Valve Cover Gasket, and the mileage is ~145K. He said that when he'd been replacing spark plugs gaskets had been ok. So, my question is could the work on spark plugs lead to failed valve cover gasket (front one). I have warranty on the work, but not sure I can prove that changing spark plugs could lead to a new problem with the gasket. Sorry in advance if my question doesn't make any sense.
Old 02-24-17, 06:47 PM
HtownBlue
HtownBlue's Avatar
It's of course possible but unlikely. Unless he removed the valve covers to replace the spark plugs (unlikely) it is not a causative effect.
Old 02-24-17, 07:28 PM
Lexuswiz
Lexuswiz's Avatar
Very unlikely, but age is a huge factor. If you're still on the original gaskets, consider changing it for peace of mind. OEM only, I've had bad luck with a few aftermarket brands.
Old 02-26-17, 11:48 AM
TriniLex
TriniLex's Avatar
Just bought Felpro brand gaskets? bad luck with those?
also whats the torque specs on the valve cover bolts and the intake plenum bolts?
thanks
Old 02-26-17, 01:11 PM
Lexuswiz
Lexuswiz's Avatar
thanks
Nope, you're safe. Felpro and Mahle? have been fine with me. Decided to save a few bucks and buying eBay no name generics for my 4 cylinders, bad bad idea.
I usually hand tighten bolts then check back, always too lazy to look for specific values. Bad I know but my hood is open every week so I see leaks immediately. But I recall ~17ft-lb for the valve cover and ~12-15ft-lb depending on which screws for the intake plenum as their are different sized screws.
Old 02-26-17, 02:53 PM
TriniLex
TriniLex's Avatar
Also lexus stated i have to replace gasket maker around Half moons?
Old 02-26-17, 09:04 PM
JoeInHNL
JoeInHNL's Avatar
thanks
The torque spec for the valve cover bolts are 8 Nm
The torque spec for the intake plenum is 28 Nm . The spec is the same for the nuts (2) and the allen head bolts (4).
Old 02-28-17, 08:51 PM
DennisMik
DennisMik's Avatar
8 Nm = 71 in lb
28 Nm - 21 ft lb
Cloxe
04-09-20 07:18 PM
931UZFE
Performance & Maintenance
13
06-20-17 06:33 AM
Aron9000
14
11-09-16 10:22 AM
GregZ1969
04-17-13 09:04 PM
mitmaks
06-24-12 08:13 AM
Quick Reply: Could spark plugs replacement lead to Valve Cover Gasket Replacement.
