engine air filter RX-350 AWD
Old 02-16-17, 02:12 PM
ajay60610
ajay60610's Avatar
Default engine air filter RX-350 AWD
Was looking to purchase an engine air filter for my 2009 RX-350 AWD [117K miles]...does anyone know the model number of one i could purchase...am close to both Walmart and Reily's Auto....dealer charges too much to replace...heard the filter just snaps into a bracket...as i am not mechanical maybe even i can handle this job....thanks.
Old 02-16-17, 03:47 PM
Lexuswiz
Lexuswiz's Avatar
I assume your local Walmart has FRAM air filters, should be CA9360 for the regular filters or TGA9360 for the tough guard version.
ajay60610 (02-18-17)
Old 02-16-17, 04:54 PM
05RX330AWD
05RX330AWD's Avatar
I purchased the Fram CA9360 as choices are limited on this Island, you should be able to handle the task......
Only 2 10mm Bolts, one directly in front & one hidden down lower in back of the filter housing, you will need an extension.
lift up the right side of the lid enough to slide out the old filter & slide in the new one.
Video here:
https://www.carcarekiosk.com/video/2...engine/replace
Old 02-17-17, 10:49 PM
lexsc4
lexsc4's Avatar
I use only OEM or Denso filters. 10 minutes job.. need a socket to loose 2 rear nuts and the rest are clamps.
Old 02-19-17, 10:05 AM
350rx
350rx's Avatar
Anyone used a K+N air filter to put in the box? to improve mpg and maybe performance?
MellonC00
RX - 3rd Gen (2010-2015)
16
04-21-18 06:50 AM
bryceis250
Maintenance
01-13-18 11:31 AM
tommy152
05-08-16 11:14 AM
GoodRevs
02-21-13 07:11 PM
harleydjce
11-23-09 09:33 AM
Quick Reply: engine air filter RX-350 AWD
