High-powered LEDs for low beams?
Old 02-06-17, 02:16 PM
sleeper408
sleeper408's Avatar
Originally Posted by Lexuswiz
Since I haven't touched my RX, not sure what the cap diameter is. Funny, on the Toyota side we use Lexus HID mounts and caps for retros, I had to source a mount cover from an ES. Regardless, it has to be enclosed otherwise you will have a bad time with moisture. Dremeling the old cap and using bits and pieces of food containers epoxied to the cap could work.
For CANBUS, there are in-line canbus eliminators that Xenon Depot sells, only thing is I don't know if they work for HID setups as they're usually used for highs but I could be mistaken. For a normal setup it would go between the LED ballast/input and the 12V source monitored by the CANBUS but with the OEM housing integrating all the wiring for the HID, AFS, and all the other crap into a single harness, you'll need to probe wires to see there is a separate line for CANBUS.
My advice, get a second set of headlights whether used or new. That way the car can still run while you tinker. Might be hard as 1. I never see RX's junked around me and 2. junk yards usually take lights off first and sell them but maybe you will get lucky depending on area. I did this for my camry so I could keep it running while I sourced parts and messed with everything.
Yeah, I was really hoping a high-powered LED kit would just plug and play (or with just simple re-wiring) for the low beams as they did the fog lights (9006). Lighting and wiring isn't my area of strength when it comes to DIY. I've also been contemplating a retrofit on the RX headlights to achieve the look, beam pattern, cutoff, etc that I really want. I've come across many videos and online threads of lighting enthusiasts taking the RX330/350 projectors and modifying the lenses and shields to make an awesome retrofit. I wish the RX330/350 projectors looked that good stock. If I can source parts (pre-fabricated brackets, lenses, etc.) cheap enough, I may just try a DIY retrofit on a secondary pair of RX headlights.
Old 02-06-17, 02:44 PM
Lexuswiz
Lexuswiz's Avatar
We drive Lexus', not everything can be simple lol
But I agree, clear lenses with an LED bulb could be a crazy combo. One of these days I'll try something crazy, since I've only had the car for about 4 months, still enjoying it for how it is
Old 02-06-17, 02:58 PM
SBMGS4
SBMGS4's Avatar
Originally Posted by sleeper408
If you're referring to my fog lights (not in the photo I posted), they are JDM astar COB LED 6500K. I have another thread going with a video of them.
Yes...will look for your other thread. I have a bulb out in one of my fogs so was thinking LED replacement possibly.....
Old 02-06-17, 05:29 PM
sleeper408
sleeper408's Avatar
I've had mine for about a week and so far, I am really happy I upgraded to LEDs for fog lights. The stock halogens looked so dim and the cheap 3030 SMD LEDs I had in there previously was purely cosmetic.
I ended choosing 6500K, which for LEDs, is actually a very pure white unlike 6000K - 6500K for HIDs, has much more of a blue tint.
So far, the 6500K color temperature and also the 4000 rated lumens/bulb in the reflective fog light housing seems to be acceptable to oncoming drivers. I have not been flashed by any oncoming drivers due to high glare.
Good luck with the upgrade!
Ham
03-11-19 07:02 AM
socaligs
CT 200h Model (2011-2017)
12-14-17 01:02 PM
exmeaguy
Lighting
07-07-09 12:35 AM
corkycal
Lighting
02-29-08 05:29 PM
corkycal
02-26-08 09:47 PM
Quick Reply: High-powered LEDs for low beams?
