PLEASE HELP !!!! Error code P0051 (P/N needed)
Old 12-31-16, 10:15 AM
papasito
papasito's Avatar
Arrow PLEASE HELP !!!! Error code P0051 (P/N needed)
Hello all, i connected my OBD scanner its reading error code P0051 bank 2 sensor 1 on my '07 lexus rx 350 (japan build), im looking to buy Denso sensor but really don't know the part number to order on Amazon. Is it the air fuel sensor or the oxygen sensor thats deffective ? Please help im really confuse and need some clarification. Thx in advance !!!
H8l8n (09-03-24)
Old 12-31-16, 10:47 AM
HtownBlue
HtownBlue's Avatar
First thing to replace is the O2 sensor. On those vehicles their are four. 2 pre cat and 2 post cat converter. Each is different in cord length and connection fitting. Make sure you purchase the correct one for whatever bank you are purchasing. Sensor 1 is pre cat sensor two is post cat. Bank one is a set of 3 cylinders that feed into the exhaust manifold, bank two is the opposite set that feed into the separate exhaust manifold opposite of bank 1.
Old 12-31-16, 02:39 PM
DennisMik
DennisMik's Avatar
Bank 2 is next to the fire wall. sensor 1 is on the top of the exhaust manifold. Parts stores call sensor 1 an "upstream" sensor.
PLEASE HELP !!!! Error code P0051 (P/N needed)-lhfjk.jpg
Old 12-31-16, 03:07 PM
BlackLexRX
BlackLexRX's Avatar
Thumbs up
Bank 2 sensor 1 is right in front of you as you open the hood and look down. It is also known as the Left, Upstream sensor. Japanese built RX of that year uses a different sensor than Canadian built. You need a Denso sensor part# 234-9008. Only use Denso as it is OEM. Double check everything, CEL, etc. Bank 2 sensor 1 Japan built is Denso 234-9008.
Old 01-01-17, 05:23 AM
RedGemini
RedGemini's Avatar
So, the diagram above is wrong? It shows Bank 2 Sensor 1 as the one at the back/firewall side.
Old 01-01-17, 08:43 AM
BlackLexRX
BlackLexRX's Avatar
Not sure about the diagram, but I understood bank 2 to face the radiator, and bank 1 to be on the firewall.
Old 01-01-17, 08:44 AM
mandyfig
mandyfig's Avatar
Go to the Denso global website and search for your spark plug.
Or else google is your friend.
Good luck!
Old 01-01-17, 08:21 PM
RedGemini
RedGemini's Avatar
That looks correct. I just realized the previous picture also shows an 8-cylinder, so that isn't specific to the RX. Thanks for posting.
Dan040286
ES - 5th Gen (2007-2012)
08-17-19 03:32 PM
Ziliton
02-11-17 02:35 PM
PandaGS300
04-06-15 01:40 PM
SICK350
03-11-14 05:20 PM
mortirius
07-28-12 03:40 PM
Quick Reply: PLEASE HELP !!!! Error code P0051 (P/N needed)
