Ignition Key wont turn, 2008 RX350 with 55K miles
I realize there have been a few topics on this, but I thought I should ask to see if I missed anything.
My wife's 2008 RX350 with 55K miles key will not turn. Its raining and about 45 degrees out. Here is what I tried, but no luck so far
- Tried 2nd key
- Tried turning the wheel hard left and right, while turning the key
- Jiggle key violently
- Hammer and screwdriver around the keyhole(Weakish taps)
- 3-1 lock dry lube
- Key de-icer
- Lift front of car, shake steering wheel, while turning key
- Use hair dryer to heat ignition.
Okay, so I gave up and decided to go to the locksmith to see if they had any suggestions or how much it would cost to look at the car.
Went into the RX350 for one last try... and it turned like nothing was wrong. Sigh, unrepeatable solutions are solutions I hate the most. I did notice that the key sometimes seemed to catch while turning on. If I tilt/push the upper left of the key while its in the ignition it would release.
I put more of the 3-1 lube in the cylinder and worked the key in and out of the hole until I was satisfied with the motion. It doesn't seem to catch now, hopefully it doesn't happen again.
So, I have had an 05 rx330 for almost a year now. it's my daily driver. One day, I'm hopping in to commute home, key won't turn. original key I got with the car, flawless up until this moment. I tried 5 more times, it wouldn't turn. each time I took the key out, waited 10 sec,might have flipped the key (shouldn't matter) inserted it again, no turn.
As I started to cuss, I did it one more time, and the key turned. WTF. hasn't happened since. I personally think it wasn't playing nice with the ecu. I personally didn't lube the lock cylinder, turned just fine when it worked.
If it happend to us, it happened to others. I just haven't had time to peruse the TSBs or do a google search about it.
Been there done that. Very frustrating. Even had the Lexus Roadside Assistance tow truck on the way one of the times, but the key turned before they arrived.
The stars aligned and it finally happened in the hands of the dealer service department while they were fixing something unrelated. It was still under warranty so they installed a new ignition lock cylinder, all was well after that.
It's not a mechanical issue of the tumblers falling correctly. it's an issue of the key being recognized. It turns just fine when it decides to work again.
When I got the RX330 it only had 1 key, OEM. I got a fleabay key, had it cut, programmed the lock and unlock. the key would turn fine, but since the immobilizer wasn't programmed for the car, it would not start. You could turn the key to the 'start' position, but you got nada, nothing. no sound no nothing.
With the original key, which was the one I usually use, and the key that would not turn at all, and then turned just fine on the 6th try, and started the car... plus the another poster said the dealership replaced the ignition lock under warranty, which means a new paring of ignition lock with a new key, tells me it's not mechanical (the key having a rough cut or something), but electronic or not being read correctly. If your key is slightly off by the cut, it would be whack every time you tried to turn it, until you 'lubed' it or whatever. it would stick a little, or you have to jiggle it to turn. This is not the case of you or me, or the poster that had it replaced under warranty the key wouldn't turn at all, and then randomly after multiple tries it works just fine again.
Anyway, that's my evidenced based theory of using keys all my life. I work for public schools, and have many keys, and trust me, I am very familiar with keys that are old, or worn or slightly not cut right and you hafta jiggle the key a little to get the tumblers to fall correctly. I have a buddy that's a locksmith I can ask him.
Several years ago we had purchased a used 2004 RX330 with 70K, parked in the garage (parked on flat surface, steering wheel was not bound by uneven surface) a week after we bought it same issue. Key(s) would not turn the ignition switch, tried all of the tricks... Tumblers got screwed up in the switch, had to replace switch. I had the shop send the new switch out to the lock smith to key the new switch to the old key. Don't let them tell you that you have to re-key the vehicle. If your keys are feeling rough going in, just a though that you may be headed this direction....
thx for posting, very helpful info.
Yes the switch did fail. Tow truck driver nor the shop could get the switch to turn, made me feel better that it wasn't just me. The shop had to dis-assemble the switch in the parking lot to get the wheels to turn to get the car inside. The switch did feel a little rough when we bought the car, I just never thought anything of it. Silly Me.....
