Blistering behind outside mirrors
Has anyone here dealt with blistering behind outside rear view mirrors? There's a shiny bit of black plastic right behind the mirrors that is blistering up in bubbles. I haven't seen this kind of thing before, but I thought I could use a syringe and some glue to squash it back down. Haven't tried it yet though before hearing if someone has a better fix.
Anyone else get this?
Just noticed it. What did you do to fix this? It's very noticeable from certain angles and in bright light. I first noticed this a few weeks ago while getting my car washed. I have it on both my mirrors so its definitely something going on with the plastic.
I had the same thing happen on my 05 RX330, mostly the driver's side mirror. I took both mirrors of and took it to a body shop to have them paint it gloss black, also took off the rear spoiler at the same time (faded) to have it painted also.
I'm also wondering if this was covered under the dash recall. I saw on guy on that thread who said he got Lexus to replace them while getting the dash replaced under recall.
Bit confused, are you guys referring to the side mirrors?
They must have sanded down the gloss black area of the mirror holders, but not the side mirror bezel itself (those are color matched to your car). A certain area of the gloss black painted area would bubble and look wrinkled, finally it peeled and had a white background. I tried a black (Sharpie) pen but that didn't work. So I got it refinished at a body shop.
https://www.clublexus.com/forums/rx-...e-mirrors.html
Mine delaminated! I am debating getting it painted or maybe skinned. Can you show us a pic of how yours turned out? Want to do something soon and can't decide. I was set on painting until visiting the Toyota body shop but they are so set in thier ways rather than practical. Thanks in advance.
When you go to take the mirror off, you only have to take off the inside bolts to drop it and let it hang to get it out of the way. The plug is in the door somewhere so you'll have to dig around in there to get it unplugged if you want it all the way off. I just let it hang and worked around it with tape.
I used a wire wheel to scuff up the beige/white background stuff that was showing through and a screwdriver and booger picker tool to scratch off all the flaking paint.
Be careful with the wire wheel not to let your drill chuck hit the bottom of the mirror while getting in the cracks. Long shank attachment would have been nice there. I used a ton of plastic packing tape around it to make sure I didn't hit anything I didn't want to.
Then just paint it on with a brush. I used a junky brush and had to pick out a few hairs, but it self-levels so all the brush marks disappear in about 10 minutes. And that was it. Let it sit a month to cure and then clearcoat.
I don't have any pics, (it's with the wife at work) but it looks great. Just make sure to hit it with a clear coat afterward because Por 15 doesn't like more than 6 months in the sun. I let mine cure for a month then lightly clearcoated it with a simple spray can. Looks great and seems to be holding just fine. It's an epoxy resin so I don't figure to have to do it again anytime soon.
https://www.lowes.com/pd/Kobalt-4-Pi...l-Set/50158911
I liked that hooked one, but don't dig in with the tip. They'll bend on ya! Just hook it off like a dentist.
