Replacing the Front Swaybar
Old 10-28-16, 05:49 AM
flipmode64
flipmode64's Avatar
Exclamation Replacing the Front Swaybar
My front sway bar broke at the end where it mounts to the links. So The whole bar needs to be replaced.
Is it as easy as removing the two bushing mounts on both sides and sliding the long bar out and replacing?
When I looked at it quickly last night it looked like it maybe went over the subframe or something.
Let me know if its as easy as I think it might be, or actually more work than just the two bushing and putting new end links on.
Thanks,
Old 10-28-16, 07:49 AM
flipmode64
flipmode64's Avatar
I called a repair shop and they quoted me 5.8 HOURS to replace this bar, is that correct?
Old 10-28-16, 09:26 AM
flipmode64
flipmode64's Avatar
It looks like it jsut rusted out and snapped at the very end where the bolt goes through to connect it to the link.
Old 10-28-16, 10:20 AM
smassey321
smassey321's Avatar
Thanks,
Swaybars can sometimes be easy. Jack up the front, remove a wheel on one side, remove the brackets and see if it can slide out. If not you may need to drop the the subframe a little. Used parts should be cheap on ebay as the bars usually don't go bad. Just get one the same thickness as what you have now.
Old 10-28-16, 10:22 AM
smassey321
smassey321's Avatar
Welding in place may also an option if removal is a complete pain.
Old 10-28-16, 11:12 AM
flipmode64
flipmode64's Avatar
I have a new bar lined up for $75 from a wrecker. Shop said they have to drop the exhaust and maybe subframe a little. Guess this isn't a driveway job for me
Old 10-28-16, 12:55 PM
flipmode64
flipmode64's Avatar
To be honest, this 2004 RX330 is the worst car I have ever owned, its literally problem after problem after problem, Never had these issues with my other cars like 96 es300, 91 ls400, 95 toyota avalon and a 99 gs300. I will never purchase an RX again after havin this one.
Old 10-28-16, 04:09 PM
numbafree
numbafree's Avatar
the front sway bar is straight forward. I helped a buddy who also has an RX330, change out his suspension. the front sway bar is just bolt on, and if you look at it, it should be self explanatory. It would be the easiest if you jack up the front end, take both wheels off and have at it.
Old 10-28-16, 04:10 PM
numbafree
numbafree's Avatar
I just got mine with 164k miles and no issues so far, after 10k miles. what issues have you had with yours?
Old 11-03-16, 08:18 AM
flipmode64
flipmode64's Avatar
Sway bar broken
clunking from back end over bumps
water leak from rear tailight, had to pull carpet out to dry
parking brake broken
numerous annoying rattles inside the car when driving on the highway
headlight height adjuster broken ( under car near rear right tire)
outside mirrors paint peeling
sunroof seal is too tight, makes grinding rubber noise when you shut sunroof
All i can think of for now
Old 11-03-16, 02:18 PM
thomas1
thomas1's Avatar
Did your car come from the Rustbelt of the United States? Is is Canadian built or Japanese built?
hypervish
RX - 1st Gen (1999-2003)
11-22-14 09:42 AM
Ariyanna
07-17-07 08:26 PM
thirdmotio
04-07-05 06:14 PM
Shinchan
Suspension and Brakes
13
08-30-01 08:13 AM
Quick Reply: Replacing the Front Swaybar
